Abs Inop????
Check the fuse first, then look at all the connections at the abs unit and at the front of each wheel and at the center of the diff. Unplug each connector and look for any signs of dirt and plug the connector back in. The abs is a durable system and any faults are usally a bad connection.
Go to my Technical aid section in my sig and scrow down to the brake section there are some links on how to trouble shoot the abs system.
hey guys i know my wheel bearings where bad so i replaced the two front hub assembly so i got two new wheel speed sensors for the front im thinking it might be the connectors to the hub assembly becuz i sprayed them with brake cleaner to clean them off i think it must of destroy the connectors???is this possible..
