95 z28 Front brake upgrade questions
Old Dec 27, 2023 | 09:37 AM
Ayjomi's Avatar
I have the opportunity to grab two spindles off of a 98 firebird. Will the larger rotors and dual piston calipers affect the abs on my 95? I’ve looked at the part numbers for the sensor on both and it’s the same speed sensor.
Old Dec 27, 2023 | 10:45 AM
Re: 95 z28 Front brake upgrade questions
A lot of people have made the change and I don't recall anyone having issues with the ABS in the 25 years that I've been here (and on similar sites dealing with 4th Gens). Can't think of any reason it would cause a problem, As far as I know all the 4th Gens use the same spindle/bearing/sensor cartridge.
Old Dec 27, 2023 | 11:37 AM
Ayjomi's Avatar
Ok sweet and for both spindles, calipers, rotors and brakes pads is 200 a good price? if I only upgrade the front to dual do I have to touch the rear or no? Is there a difference in the rear between the 93-97 to 98-02? And where can I find the torque spec for ball joints etc?
Old Dec 27, 2023 | 04:32 PM
I have no idea what these parts cost, used or new. Yes, 98+ rear brakes are an upgrade. But no urgent need to upgrade the rear. The fronts do most of the work. Gets messy because the E-brake is a different design.
Old Dec 31, 2023 | 11:51 AM
Ayjomi's Avatar
Thank you I did the conversion, fixed one of my abs sensors up front but the ones in the rear are ****ed either way. From what I’ve seen there is no replacement abs sensors for rear on 95 traction control made anymore correct?
could I replace entire rear end to newer one?
Old Dec 31, 2023 | 01:59 PM
Don’t know what's available for replacement rear TCS sensors.
If you're looking for an upgrade, like a 12-bolt or Dana 60, check with Strange Engineering. They may have a solution to TCS. I had a Strange 12-bolt with only ABS, and Strange supplied a single ABS sensor (non-stock) that worked, but it was not very reliable. Moser is another source for a 12-bolt.
Finding a used stock complete rear would also be an option, as long as it had the two ABS/TCS sensors. Any year 1995 to 2002 would work, although you would have the 98-02 parking brake activation issue. The 98-02 parking brake is a pair of shoes inside a small “drum” that’s part of the brake rotor. The cable arrangement is different. The replacement rear would also have to have the limited slip carrier and the same gear ratio as you currently have. A different ratio would require reprogramming the PCM.
ZEDDY
Dec 24, 2023 04:25 AM
Ansley
9
Oct 28, 2010 07:49 PM
ZMEFLY
Mar 13, 2005 10:11 PM
BitchinRS
Parts Wanted
Jul 10, 2004 10:54 AM
supermo26
Sep 9, 2003 10:55 AM
