95 V8 Z28 stock spring specs
Old Mar 6, 2013 | 09:39 PM
Woody95's Avatar
I want to buy stiffer springs for the rear but I can't seem to find the stock spring weight. Does anyone know?
Old Mar 7, 2013 | 08:30 AM
NJ-LE's Avatar
Re: 95 V8 Z28 stock spring specs
Woody95:
I found the following some years ago ... I can't remember if it was a faq from Injuneer or Shoe Box ...
Q: What are the specs on the stock sway bars and springs?
A: The V6 models have a 30mm front sway bar and a 17mm rear sway bar. The spring rates are 223 pounds per inch in the front and 95.4 pounds per inch in the rear.
The regular V8s have a 30mm front sway bar (same as V-6 model) and a 19mm rear sway bar. The springs are 292 pounds per inch up front and 114 pounds per inch in the rear. The 1LE and WS6 suspension package has a 32mm front sway bar and 19mm rear sway bar (note, 1993 and early 1994 1LEs got a 21 mm rear bar). The springs are 360 pounds per inch up front and 130-180 pounds per inch (progressive) in the rear (note, 1993 1LEs got the same springs as regular V8s).
Noenav
Mar 1, 2019 07:38 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
wytblur
Mar 2, 2003 03:40 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
