94 z28 help when i turn right makes rubbing noise ???
Old Aug 2, 2015 | 04:32 PM
colts0455's Avatar
still getting things done to my 94 z28. im pretty sure needs new brakes soon but when i turn hard right or when im turning hard left makes like a rubbing noise. at 1st thought was tires rubbing the inner fenders but the tire size are right i need help is this bad ?
Old Aug 3, 2015 | 09:38 PM
colts0455's Avatar
Re: 94 z28 help when i turn right makes rubbing noise ???
? any one
Old Aug 3, 2015 | 11:03 PM
ZZ's Avatar
ZZ
You might have better luck posting in the technical discussion area.
Old Aug 4, 2015 | 12:13 AM
Fatdog2's Avatar
Is the power steering pump fluid level ok?Any leaks?
Old Aug 4, 2015 | 09:47 AM
colts0455's Avatar
zz ahh i thought this was just all lt1 post lol. and no power steering ok its a really bad rubbing when i do a hard right turn. sounds like rubber rubbing had windows down and can hear it kind of loud not a pop or grind or sequel just like rubbing.
Old Aug 4, 2015 | 11:52 PM
Fatdog2's Avatar
Back in the day,years ago when dinosaurs were around(me) it was the rack going south.I would take it to a brake place and have them put the car with you in it up on the lift and see if this can find the problem.hope this helps.You turning the wheel left and right with no load.
Old Aug 5, 2015 | 12:28 PM
colts0455's Avatar
fatdog2 are you saying rack and pinon going out wish i pray to god its not. yes im just doing normal turning with me in it really bad when i turn right. its like tire rubbing noise best way to explain it.
Old Aug 5, 2015 | 02:14 PM
ZZ's Avatar
ZZ
Is it in the front or back? Rear brakes can make noise too from the play in the axle.
Old Aug 5, 2015 | 02:54 PM
colts0455's Avatar
front right when i give it good turn like Sharpe turn makes rubbing noise not a pop or grinding noise just like rubber on rubber. i took it into a parking lot yesterday turn radio off rolled windows downs its a good sound you can hear it. just hoping its nothing bad cause ill done put good bit money in this car.
Old Aug 5, 2015 | 05:49 PM
ZZ's Avatar
ZZ
Check for witness marks. Look for anything that looks like it was rubbing. The jack that corner up and see if the hub bearings ball joints, bushings and or tie rod ends are worn by wiggling the tire up-down and side to side. If you have play in either direction, it'll get you closer to finding it. Unfortunately, it's hard to diagnose a noise without being there. Let us know what you find.
Old Aug 5, 2015 | 06:17 PM
colts0455's Avatar
kk will do that tomorrow its raining here know ill keep yall updated. thanks for yalls input as well
Old Aug 5, 2015 | 11:29 PM
Fatdog2's Avatar
Rain?(California here).
Old Aug 7, 2015 | 06:20 PM
colts0455's Avatar
after 3 days got lil clear, the noise was coming from the right rear of the car not the front right, so i went today got gear oil filled it up it was low took over half of a 32oz bottle ? took her back out its still doing it, making like a rubbing noise when i do a left circle ? a full left circle im pretty sure she needs brakes could this be it i looked under it while i was up under the car seen nothing out of place ?
Old Aug 7, 2015 | 09:15 PM
ZZ's Avatar
ZZ
Post #8. The axle can move enough to cause noise. My 97 did this after changing out the rear. I used a 3 channel rear, and the 4 channel backing plates and axles from the car though. I think I had to shim the caliper, it's been a long time. Try new brakes and see how it sounds. You need them anyhow so it can't hurt. Check how much axle end play you have too while you're in there.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jj71787
Dec 30, 2014 02:15 PM
ro2207
Dec 4, 2014 06:18 PM
squarehead
Nov 21, 2014 08:02 PM
