4th Gen Rear SQUEAK!!!!
Old Jun 25, 2004 | 03:58 AM
dregsz's Avatar
This has been driving me nuts for like a year.
I can't figure it out and it's driving me NUTS!!!
I have a rear suspension squeak.
It squeaks alot, I have greased all the fittimgs in the poly bushings, I changed out the spring isolators and wrapped the bottom of the spring in fuel line.
The only thing I haven't checked is the top nuts on the shocks, (bilstien HDs)
Am I missing something?
This Sucks!!
edelbrock LCAs, poly bushed PHB, Bilstien HDs and eibach prokit.
HELP!!!!
Old Jun 30, 2004 | 12:04 AM
Steve in Seattle's Avatar
best guess: poly's too tight or not greesed enough.
The PHR application is less than ideal really. My rod-end PHR makes no noise... and that's one less poly item to worry about greesing.
Let us know if you track it down... it's GOT to be a joint somewhere... and rubber doesn't squeek. Look for the poly, and check the torque specs.
stylin99
Feb 3, 2016 02:24 PM
guruerror
Mar 4, 2015 06:25 PM
Jul 4, 2005 05:00 PM
formula79
23
Jun 20, 2002 01:42 PM
