3rd Gen Guys, has anyone used PA K-mambers?????
Old May 13, 2006 | 02:57 PM
globalco's Avatar
It seems PA has the least expensive K-Members, are they any good? I am not super concerned about cosmetic stuff, do they do they install without hassle and do the job?
Thanks,
Jim
Old May 13, 2006 | 06:18 PM
Dave K's Avatar
Re: 3rd Gen Guys, has anyone used PA K-mambers?????
Do a search... there've been some negative reports regarding fitment
Old May 14, 2006 | 06:28 PM
respectirocz's Avatar
not good
i dont recommend
different people have had different problems
what they say over the phone and what they're website says doesnt always agree
the problems i had with my k-member
the motor mount plates were welded too close together by about 1 cm, my engine does not simply drop in, i have to "stretch" the cross member to make it fit
the pa racing k-member doesnt not use the stock 6 bolts to bolt to the chassis, you need shorter bolts and they only offer them in metric 8.8 class, instead of 10.9 class
i damaged the original control arm bolts so i ordered new bolts from pa racing
the bolts they gave me were too large for the holes in the k-member
the bolts in their control arm kit were too large for their own k-member
i ordered mine powdercoated black
the so called powder coating is peeling away as we speak
i presume it is simply gloss black spray paint
the spring seats in both the k-member and the control arm have 3 evenly spaced welds around the circumference, i would have prefered a continuous weld around the circumference but i suppose it will hold fine.
those are my qualms with pa racing, if you go to thirdgen.org you'll find more
if i could do it over i would have saved a little more money and bought one from basically anyone else
Old May 15, 2006 | 02:29 PM
383Z's Avatar
I bought mine when they first came out and only one other k member was available It has been in my car for 4 years without an issue. But yes some people do have issues but someone has an issue with everything that is put out. But honestly there are better ones available now. And mine will come off to get jet coated when I redo my front suspension.
Dec 31, 2014 02:21 PM
Red97LT1
Aug 7, 2002 05:45 PM
19redta96
Jul 23, 2002 12:25 PM
JasonD
Jul 15, 2002 02:17 PM
formula79
23
Jun 20, 2002 01:42 PM
