Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Yank torque converter group purchase
Old Jan 26, 2004 | 09:52 AM
tbyrne's Avatar
We're current running a group purchase that covers 5 models of the Yank torque converters including the LS1 and LT1 f-body -
LS1 Camaro/Firebird
SY3500 LS1 Super Yank 3500 (258mm super high efficiency, 3500 stall, 1.61 STR)
SS3600 LS1 Super Stock 3600 (245mm very high stall torque ratio due to 21 blade stator, hard hitting launch, 3600 stall, 2.50, 2.55 STR)
SS3800 LS1 Super Stock 3800 (245mm very high stall torque ratio due to 21 blade stator, hard hitting launch, 3800 stall, 2.50, 2.55 STR)
SS4000 LS1 Super Stock 4000 (245mm very high stall torque ratio due to 21 blade stator, hard hitting launch, 4000 stall, 2.50, 2.55 STR)
SS3800E LS1 Super Stock 3800 Extreme (245mm, 21 blade stator, Posi lock-up clutch w/kevlar lining, 6 bolt mounting lugs lightweight billet cover, 3800 stall, 2.60 STR)
SS4000E LS1 Super Stock 4000 Extreme (245mm, 21 blade stator, Posi lock-up clutch w/kevlar lining, 6 bolt mounting lugs lightweight billet cover, 4000 stall, 2.60 STR)
Super Stock 4000 (245mm, very high stall torque ratio due to 21 blade stator, hard hitting launch, 4200 Stall, 2.60 STR)
Super Stock 4200 (245mm, very high stall torque ratio due to 21 blade stator, hard hitting launch, 4200 Stall, 2.65 STR)
Pro Thruster 4000 (245mm, Stall speed 4000 through 4600, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
Pro Thruster 4200 (245mm, Stall speed 4000 through 4600, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
Pro Thruster 4400 (245mm, Stall speed 4000 through 4600, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
Pro Thruster 4600 (245mm, Stall speed 4000 through 4600, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
LT1 Camaro/Firebird
SS3600LT1 YANK SUPER STOCK 3600 (245mm, very high stall torque ratio, hard hitting launch, 3600 stall, 2.50 STR)
SS3800LT1 YANK SUPER STOCK 3800 (245mm, very high stall torque ratio, hard hitting launch, 3800 stall, 2.50STR)
SY3500LT1 SUPER YANK 3500 (258mm super high efficiency, soft launch, 3500 stall, 1.61 STR)
SY4000LT1 SUPER YANK 4000 (258mm, 4000 stall, 1.86STR)
SS4000LT1 YANK SUPER STOCK 4000 (245mm, very high stall torque ratio, hard hitting launch, 4000 stall, 2.60STR)
SS4200LT1 YANK SUPER STOCK 4200 (245mm, very high stall torque ratio, hard hitting launch, 4200 stall, 2.65STR)
PT4000LT1 YANK PRO THRUSTER 4000 (245mm, 4000 Stall, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
PT4200LT1 YANK PRO THRUSTER 4200 (245mm, 4200 Stall, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
PT4400LT1 YANK PRO THRUSTER 4400 (245mm, 4400 Stall, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
PT4600LT1 YANK PRO THRUSTER 4600 (245mm, 4600 Stall, Posi Lock-Up Clutch w/Kevlar Linings, lightweight billet cover, 2.2-2.7 STR)
Due to Yank's guidelines I can't post pricing for the GP but you can receive a quote by giving us a call or e-mailing tbyrne@tbyrne.com.
10 or more orders are required by the closing date of Wednesday, February 4th for this GP to go through. Orders can be placed online or by calling 1-877-4-TBYRNE.
IMPORTANT INFO: Most products to fill each GP are ordered at the end of the GP. They usually take 1-2 weeks to ship from here, but some items could take longer based on the size of the group purchase and availability with the manufacturer. Depending on the product and our available stock, some orders will be shipped from here shortly after the GP comes to a close. Remember, you need to place your order if you are interested in taking part in a GP. Be sure to check the status of the GP that you are part of on it's closing date to see if is going through.
MORE IMPORTANT INFO: All credit cards are processed a few days before the GP closes to insure everything will go through without a problem and to lock in the order. Orders canceled after your GP order has been processed will be subject to a 10% processing fee. Orders for products that are non-stock items (not normally kept in stock) can not be canceled so be sure that you would like to be part of the GP before you place your order.
WHEN SHOULD YOU PLACE YOUR ORDER?: We find that alot of people wait for the required number of orders to be placed before they get in on the GP. If everyone does this the GP minimum is never met. If you would definitely like to join one of the group purchases that are listed it will be best to place your order as soon as possible. Your credit card won't be charged until just before the GP comes to a close (as long as there are enough orders) and the minimum will be met much sooner. This will allow you and the other participants to take advantage of the savings.
Have a good day,
Tom
Old Jan 30, 2004 | 08:55 AM
tbyrne's Avatar
We now have 11 orders in so this GP will be a go! This will be wrapping up on Wednesday (2/4).
QuickSilver02
Apr 7, 2015 11:12 AM
armedtrigger
Feb 24, 2015 08:30 PM
StansZ28
Feb 19, 2015 07:39 AM
PCLZ28
Parts Wanted
Feb 12, 2015 11:35 PM
Collector Car
Dec 17, 2014 01:12 PM
