Wide band/Lambda GP
Innovate Motorsports Wide Bands
1) The Basic Kit Innovate Motorsports kit ($315) includes the LM-1 meter, a Bosch wide-band oxygen sensor, 10 ft sensor cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and quick-start guide.
2) The RPM Kit ($389) is comprised of the basic kit plus the LMA-2 (RPM Converter.) This cable contains a circuit to convert a tach signal into an analog RPM signal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other 0-5 V analog sensors from your vehicle.
3) The AuxBox Kit ($535) is comprised of the basic kit plus the LMA-3 (AuxBox) input Expander Cable. The AuxBox will give you the choice of picking sensors existing from the vehicle or use the 5 internal sensors. The five internal sensors are: RPM conversion (from a tach signal or inductive clamp), Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), Acceleration, and Injector Duty Cycle (Dwell).
The LC-1 is a complete wideband controller built in to a sealed cable. It features the same award-winning patented digital measurement principal found in the LM-1, and includes digital input, output, and 2 programmable analog outputs.
-INN-3744 ($139.99)
-INN-3769 (179.99)
-INN-3744 ($139.99)
-INN-3769 (179.99)
Bails098
Aug 17, 2015 05:15 PM
May 21, 2015 01:04 PM
mark0006
Apr 21, 2015 12:42 PM
Dec 1, 2014 08:08 AM
