Strange 12 bolt with the SS posi - $2189.99!
Strange is no longer offering their f-body 12 bolt with the standard differential. It's now only available with their Super Strength posi. This will insure that you don't have any worries when bolting on sticky tires and pulling the front tires off the ground at the track. The Strange rears are pretty much ready to bolt in. The only assembly is moving the brakes from the stock rear to theirs. They will need to build brake backing plates into the rearend. This can be done by you supplying a set, purchasing a new set or using one of the cores that we have -
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles.
The backing plates are only required for 1998+ cars.. $229.99
We have Strange 12 bolt on sale for $2189.99!
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763)
Re: Strange 12 bolt with the SS posi - $2189.99!
These rears are shipped freight collect and are usually in the $125. - $200. range. You wouldn't be able to pick this up at the terminal because they have to be sent to the billing address for your card.
Thanks,
Tom
Thanks,
Tom
Yes, this is everything ready to install. The only thing that has to be done is swap the brakes from your rear to the new one. There are some brake backing plate options that need to be looked at for the LS1 cars.
The backing plates aren't needed if you have an LT1 you would need to send your axles into Strange so they can take the reluctor rings off. They need these if you'll be keeping the traction control.
carguyshu
Jan 22, 2017 11:19 AM
