Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Strange 12 bolt rearend GP
Old Dec 29, 2003 | 08:49 AM
tbyrne's Avatar
We are offering a group purchase for the Strange 12 bolt rearends. 3 or more orders are required for the following pricing -
PRG210 - Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - Gear ratios available are 3.42, 3.73, 3.90 and 4.10. GP Price - $2059.99
The 3.90s are kind of noisy so Strange doesn't promote this one but they available.
Options
PRGOP8 Upgrade to US/Strange 33 spline Super strength posi-unit (w/o reluctor ring - ABS on side of pumpkin) $145.00.
PRGOP14 Upgrade to US/Strange 33 spline Super strength posi-unit (w/reluctor ring - ABS on top of pumpkin) $145.00.
Strange recommends the Super Strength posi upgrade if the car will see any track time or hard driving.
PRGOP10 Upgrade to aluminum support cover $115.00
gmbbp - GM brake backing plates - You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings off of them. $229.99.
gmbbpcore - If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars. - $229.99
The Strange rears are shipped freight collect so you will need to take care of the shipping charge when the driver delivers. The trucking company will usually call a few days ahead of time to set up the delivery. Transportation cost will depend on where the rear is going. It usually falls into the $150.-$200. range but could be more if you need a lift gate. Two guys can pull these off of the truck without a problem. These rears are shipped assembled and ready to be bolted in when you receive them.
Orders can be placed online or by calling 1-877-4-TBYRNE. This GP will be running until Sunday evening (January 11th). We'll submit the orders to Strange as soon as we receive a total of 3. Any orders over 3 will be submitted as they come in.
Tom
Old Jan 5, 2004 | 08:42 AM
tbyrne's Avatar
1 week left!
Old Jan 11, 2004 | 11:35 PM
TCAL95Z's Avatar
I just placed my order
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
SABLT194
Aug 21, 2002 07:45 PM
SABLT194
Aug 3, 2002 09:33 AM
