Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Ship free on long/short blocks
Old Dec 1, 2008 | 07:41 AM
Revolutionary's Avatar
We are offering an end-of-year sale to include FREE SHIPPING on all of our long and short blocks purchased until end of day 12/31/08.
Our most popular include...
SHORT BLOCKS
Bare Bones Street/Strip LT1 383 LT1block, Eagle cast steel 3.75" crank, Eagle SIR 6" rods, KB 19cc dish pistons (10.6:1 with stock heads), 1/16-1/16-3/16 file fit rings, balanced for factory flexplate and damper. No cam or timing set or crank key $2349
Street/Strip LT1 383 LT1 block, Eagle cast steel 3.75" crank, Eagle SIR 6" rods, KB 19cc dish pistons (10.6:1 with stock heads), 1/16-1/16-3/16 file fit rings, Comp Cams hydraulic roller cam, LT1 timing set, balanced for factory flywheel and damper. $2699
Competition LT1 396 LT1 block with 4 bolt mains and ARP main studs, Eagle 4340 steel 3.875" crank, Eagle ESP H beam rods, Custom Diamond Racing Pistons (any compression), file fit rings, hydraulic roller cam, LT1 timing set and crank key for correct year, internally balanced $4049
LONG BLOCKS
Street/Strip LT1 TRICK FLOW 383, LT1 block, Eagle cast steel 3.75" crank, Eagle SIR 6" rods, KB 19cc dish pistons (10.6:1 with stock heads), 1/16-1/16-3/16 file fit rings, custom hydraulic roller cam and lifters, LT1 timing set, balanced for factory flexplate and damper, Trick Flow 195cc LT1 heads, narrow 1.6 roller rocker arms and hardened pushrods $5249
Competition LT1 Stroker AFR 383, LT1 block with ARP main studs, Eagle 4340 steel 3.75" crank, Eagle ESP 6" rods, SRP 5cc valve notch pistons, Sealed Power file fit rings, hydraulic roller cam and lifters, LT1 timing set, internally balanced, pushrods, Air Flow Research 195cc LT1 heads with spring and valve upgrade, locks, and seals, aluminum race series narrow 1.6 rocker arms standard, no balancer or flywheel $6499
F'n1996Z28SS
Aug 23, 2023 11:19 PM
HectorM52
Jul 30, 2017 11:46 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
Elcojoe
Nov 17, 2014 10:27 PM
