Pre-made OVC igntion wires for LT1
Tired of cutting and measuring.
Elitesparkplugs.com does all the work for you. We are know offering ovc wires in 8 & 9 mm (with optional heat shield protection)
We guarantee these wires for life!
For Prices Click here
Re: Pre-made OVC igntion wires for LT1
well are these good wires??? ( low resistance ) i need to order wires asap, and these seem like a good fit, just wondering what the quality is like compared to taylor and msd. thanks
Top notch but don't take my word for it. Post around and you will see how much people like them.
thx Jim
is there anything better with going 9mm instead of 8mm. i have wire looms for 8mm that im sure i can drill to make em fit. and does the heat shield make the wire thicker or is it just a different material the wire is in?? im kinda thrown off on what this heat shield is.
Originally Posted by eagleknight97
Yeah, what is the difference in the non-heat shielded ones and the heat shielded ones? And yeah, what is the advatage of going with 9mm over 8mm??
I will be ordering a set of these right quick. I need to know 2 things first:
1. What is the advantage if any on a bolton car going with 9mm over 8mm.
2. What brand of wires are these?
The difference between the 8mm vs 9mm offers better interference protection. This helps to prevent misfires, cross firing or sensor interference.
These wires are made by Malboo LLC. Which is the owner of Elitesparkplugs.com.
Thx Jim
