Nitrous Special..
Nitrous Special..
Ok Guys its back by Popular demand.That right ....
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.Your choice in white or Black Bottle.(The Bottles will have NXs NEW 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99.
With this system we GIVE you for FREE a new smooth bellows (50.00 Value) :eek2:
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Dave
With this system we GIVE you for FREE a new smooth bellows (50.00 Value) :eek2:IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Dave
Re: Nitrous Special..
Hmmm how long is this deal going on? Im a little low on the cash, just spent it all on the 9inch. Also I was wondering if you could pm me with a little explanation with the difference between wet and dry kits. I heard the wet kits arent as safe as the dry kits...so would I be able to run the hundred shot on my stock lt1 with this kit? How safe would this be(I have 96k on motor too)? Thanks, Jason.
RUENUF
Mar 13, 2016 03:37 PM
