Meziere Elelctric LS1 Water Pumps - Great Deals Inside!
The Meziere pumps have been tested at the track, on the dyno and most importantly, during street driving. They have allowed engines to run cooler at low speeds and gain high end horsepower. In addition to the released power, you get to keep all of your factory accessories. Taking quality to the extreme, the WP319 features a dual bearing belt idler, billet parts throughout, and a “weather-tite” electrical connection. The pump is backed by a two-year warranty.
Features:
Purpose built for street use – 3000+ hour life expectancy.
Fully polished or anodized in your choice of 4 colors (Black,Blue,Red,Natural).
Chrome upgrade available.
55 GPM free flowing rating.
All stainless steel hardware included.
Heater and bypass provisions.
Light weight. Complete standard pump weighs only 14.9 pounds!
Stainless steel large diameter main shaft with high performance ceramic seal.
Inlet fitting supplied to match stock configuration.
Easy install - truly a "bolt-on" pump.
Full two year warranty - the best in the business!
Finishing The System:
This pump is supplied complete with gaskets and hardware, complete and ready to bolt on. The only additional item you will need is a standard Chevrolet thermostat if you desire to use one. It will install behind the exit fitting located above the idler pulley.
Amperage draw:
Under normal use the pump will draw 11-12 amps.
Overall Height Dimension:
The standard pump is 7.88" long from the mounting surface to the tip of the pump.
Pump Weight:
This application weighs 14.9 lbs.
Other colors -
WP319N Meziere electric water pump (natural) with thermostat
WP319R Meziere electric water pump (red) with thermostat
WP319B Meziere electric water pump (blue) with thermostat
WP319PU Meziere electric water pump (purple) with thermostat
WP319U Meziere electric water pump (polished) with thermostat
WP319C Meziere electric water pump (chrome) with thermostat
NOTE: New pumps now say LS instead of LS1.
This is another product that is covered by our Everyday Low Pricing Policy! Pricing is lower than we are allowed to advertise so we have to ask that you give us a call at 1-877-482-9763 or e-mail tbyrne@tbyrne.com to receive a quote.
Have a good day!
TBYRNE MOTORSPORTS LLC
ORDER LINE - 1-877-4-TBYRNE
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR OUR EVERYDAY LOW PRICE POLICY!
Features:
Amperage draw:
Pump Weight:
Other colors -
Have a good day!
