Mac Performance rear end girdles for 10 bolt $122.95 SHIPPED !!
Strengthen your GM rear end with the strongest rated support covers you can buy !! These 356 T-6 Aluminum covers help keep the rear end housing from distorting under load , preventing increased side bearing clearance and ring gear deflection . Two special adjustable grade-8 support bolts help prevent both bearing main caps from movement and possible breakage . Increased fluid capacity , fill , drain plugs and hardware .
Thanks ,
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Thanks ,
Mike
585-865-1832
oldschool
Feb 9, 2016 09:21 PM
