Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Let's do another C5 to Fbody front brake conversion brackets (Bishop)! LIMITED GP!
Old Dec 13, 2006 | 08:43 AM
  #151
trackbrackets's Avatar
Sweet. Nevermind then.
Old Dec 15, 2006 | 09:40 AM
  #152
RickS's Avatar
thanks for your updates, it took a while but in the end was well worth it. These things were made nice. I got them in the mail yesterday, and installed them by 8:00pm, they look and work great
Old Dec 15, 2006 | 12:25 PM
  #153
Wow, you didn't waste any time. Glad to hear that you're pleased with them.
Old Dec 15, 2006 | 03:25 PM
  #154
PoorMan's Avatar
Received mine. Top quaility.
Old Dec 15, 2006 | 03:57 PM
  #155
96ss2nv's Avatar
+1!
Old Dec 15, 2006 | 07:36 PM
  #156
Happy_Dan's Avatar
Mine showed up too. Thanks very much. They are all that they have been said to be. Very nice work!
Let me know if you end up with another batch. I will try to sell some more for you.
Old Dec 15, 2006 | 07:56 PM
  #157
SpeedSpecialty's Avatar
Glad you guys are happy, this GP was not as easy as the previous ones. Thanks again for your patience!
Old Dec 16, 2006 | 08:01 AM
  #158
Thanks Dan, I'm glad you like them, and I always appreciate referral business.
No, this one was a bit rough. I think the Thanksgiving holiday added about a week to our delivery time and all of the shops were busy which cost us a few days here and a couple there. This batch really took a long, long time. I still can't see exactly where all the time was lost, but it was surely lost somewhere along the way. I apologize for all the delays. And, I'm glad to hear that they were worth the wait and that you're pleased with the kits.
Old Dec 18, 2006 | 02:56 PM
  #159
RickS's Avatar
a word of advise to everybody before you start cutting, make sure that the metal "dust" does not get onto the cars paint, because it will stick into it, making one hell of a problem. i should know, because i have to find a way to remove the metal dust from mine
looks like ill be wetsanding
Old Dec 18, 2006 | 09:51 PM
  #160
Did you use a bit of oil on the blade when cutting? It helps to keep the dust down and keep the blade and the metal that's being discharged a bit cooler so it's less likely to stick to the paint (and your blades last longer). I can't say I've had anyone mention that being a problem before, but I could see how it could happen.
Old Dec 18, 2006 | 10:11 PM
  #161
cjmatt's Avatar
ill prob end up using a cutoff wheel then
Old Dec 19, 2006 | 07:50 AM
  #162
You'll be better off with a sawzall, or some type of saw. The cutoff wheel discharges material at much higher temperatures and throws it farther than a saw does. I'd expect that it would have more of a chance of embedding stuff in your paint. If you use a saw blade and keep oil on it, you shouldn't have any problems (at least not in most cases). The oil cools the material so it's not hot enough to stick in the paint.
Old Dec 22, 2006 | 09:46 PM
  #163
RickS's Avatar
No i didnt use the oil, i was using an electric grider with a cut off wheel. Its real thick tho, so it put allot of metal dust in the air.
afterwards i tried to wash it off, but the metal was stuck in the paint, once it got wet and dried, you could see where it turned brown from rust. i ended up wetsanding the whole car and buffing the shine back, major pita
good tip with the oil and a sawzall, If i were to do it again i would have used tha saw
Magenta_Hearts
Mar 29, 2017 08:54 PM
Brake_L8
Jan 20, 2015 09:44 AM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
slocody
Feb 10, 2003 01:04 PM
