JetHot LT1 header GP and New Cats!
It has been a little while since the last Jet Hot LT1 header GP and we have been contacted several times to start a new GP. We would like to add a twist to this GP.
Jet Hot has been working on a Y pipe with Cats for the LT1 header. We already manufacture a Y pipe with Cats for the LS1 headers and has been VERY successful. Due to our plant production, we won't have a LT1 Y pipe ready till early next year(sorry). BUT, we have the small high flow Cats on the shelf for the Y pipe. They were designed and tested with the Jet Hot LS1 Y pipe. They are not emission certified but have been tested and have passed the emission test. They are very small, about 4" diam and about 4" long. On the LS1 Y pipe, they are deisgned to slide into the pipe were it was expanded and held in place by a 3" wide band clamp. If anyone wants to purchase this small Catalytic convertor, it can be adapted to any 3" diam pipe on the market. The pipe it goes into would need to be cut and expanded to 3 1/2" for the cat to slide in place on both sides then either weld or clamp it down. It would not be coated.
The price for the small high flow catalytic convertor is ***$100+s&h to the door***.
We are also offering the Hooker off road Y pipe,fully coated in&out with the sterling silver finish,for ***$192+$20s&h to the door(within the U.S.)***.
JET HOT LT1(93-97) long tuber headers (1 3/4x3" collectors with a 3 bolt flange at the end. O2 bungs installed into both collectors. 16 gauge metal with a 3/8" flange thickness,comes with the bolts and gaskets) ,fully coated in&out with the sterling silver finish is ***$499+$25s&h to the door(within the U.S.)***.
We also offer the same LT1 headers with emission tubes for the 94-97 LT1. They are also full coated and run ***$499+$25s&h to the door(within the U.S.)***.
If you need the O2 est wires, we sell them for ***$15 each***.
We also carry the fitting for the 97LT1 cars that will connect the emission tube to the emission tube on the header(we found that GM had changed the size of the tube from previous years). The fitting is ***$10***.
As always, you can pay all at once or in 2 payment(by credit or debit card).
The GP will run till Friday (10/17/03). If you have any questions or wanted to place an order, please contact me.
Chris
1-800-432-3379 ext 110
chris@jet-hot.com
Chris
chris@jet-hot.com
No LT1 dual-cat y-pipe until next year? I understand...but I'm still disappointed.
Who manufactures the cats? Any flow numbers for them?
EDIT: Also, Chris, some of the '96 cars require those AIR fitting adapters too (mine did). Just FYI.
Originally posted by jasycZ28
Please tell me that you guys are in the process of making the 93 with the emissions hookups? If so do you have a timeline?
Chris
chris@jet-hot.com
Originally posted by squirrelmaster
oh yea, ask and ye shall receive!!
quick question, if i was to buy the headers along with the hooker y-pipe, would the total cost be eligible for that payment split thingy?
Yes, the 2 pay plan can be used.
Chris
chris@jet-hot.com
Originally posted by Chuckels
When are the payments due? I may be able to swing it.
Chris
chris@jet-hot.com
man, i cant wait for the 15th... oh yea..
Chris, i think i saw you on rpm2night or speedvision a couple nights ago... the announcer was talking to you at a jet-hot stand and you were talkin about your product.. was cool to put a face to the type..
Chris
