Jet Hot Coated Kooks and Dynatech Long Tube Header Special!
We're received alot of requests for our Jet Hot coated header specials so we've brought these back until Sunday, March 26th! Each manufactuer has part numbers available for many different vehicles so we're going to make it easy. You can add Jet Hot coating to any set of Kooks or Dynatech long tube headers for only $149.99! This will save you $100.00 off of the regular price! Most of the header prices on our website already have a built in discount to save you money off of the manufacturer's retail so this is like receiving a double discount!
If you would like to order the headers without coating we can offer you free shipping for orders being delivered in the 48 states.
JET-HOT® develops, produces and applies a variety of coatings. Properties of the various coatings include insulation, corrosion resistance, abrasion and impact resistance as well as lubricity. All are applied through a meticulous, multi-step process including: thermal degreasing, abrasive-blast stripping with virgin aluminum oxide, double-coating (inside and out on headers), high temperature curing, custom packaging for return shipping, and quality-assurance controls during every phase of the procedure.:
JET-HOT 1300™ - Jet Hot's exclusive formula works beautifully on new or used parts at temperatures up to 1,300°F. Sterling™ is the most popular finish. This high-luster coating, containing silver powder, shares the brilliance of chrome with the subtlety of nickel. It provides the most brilliant appearance in high-temp, high-tech coatings while delivering major performance advantages. Sterling™ is also an extremely easy coating to keep clean. The same basic formula is available in matte black, blue and cast-iron gray.
Horsepower gains depend on many variables, including engine size, type and setup; cooling system performance; ambient temperatures; and other factors.
Nevertheless, JET-HOT Sterling will normally boost power when applied to headers for two reasons. First, the coating promotes denser, more potent fuel/air charges by insulating the engine bay from exhaust heat. At the same time, it accelerates the pulsed-vacuum effect on “tuned” headers, resulting in more effective scavenging of cylinders. The increased velocity of exhaust gases produced by higher exit inertia not only clears each cylinder more quickly; it also draws in the next fuel/air charge more efficiently.
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Have a good day!
ORDER LINE - 1-877-4-TBYRNE (1-877-482-9763)
E-MAIL - tbyrne@tbyrne.com
CHECK OUR WEBSITE FOR CURRENT SPECIALS!
WE HAVE YOUR FORCED INDUCTION NEEDS COVERED WITH - ATI, VORTECH AND MAGNUSON SUPERCHARGERS ALONG WITH STS TURBOS!
Have a good day!
Jul 4, 2005 05:00 PM
