Introducing FFHP's Stage 1 LS1 Cylinder Heads!
We are now offering a high quality low cost LS1 Stage 1 Cylinder head. Here is what you will get
Stage 1 Heads
Hot Tanked and Pressure Tested
Stage 1 Ported
2.02 FFHP Performance one piece stainless intake valves
1.57 FFHP Performance one piece stainless exhaust valves
Lunati Single LS1 Springs (good to .600 lift)
Titanium Retainers
Bronze Valve Guides
New GM Keepers
New GM Spring seats
Viton Valve Stem Seals
3 Angle Valve Job
Milled up to .040
Flowed with sheet
Price $1395.00 (no core required! no core charge!) Add$100.00 for 6.0L heads.
However we will refund $250.00 of the above price if you send us your stock heads back to us!
We have a number of heads in stock including a set or 2 of the 5.3L and 6.0L heads. Also have a set or 2 of 1998 style heads in stock
Flow numbers are
Lift Intake Exhaust
.200 153 118
.300 212 166
.400 243 183
.500 281 212
.600 293 221
Many other options available! Contact us to discuss your application! Scott@FFHP.net or call 502-648-1192 or 502-648-1093.
LT1 Heads Coming Soon!
Stage 1 Heads
Stage 1 Ported
Titanium Retainers
Bronze Valve Guides
New GM Keepers
New GM Spring seats
3 Angle Valve Job
Milled up to .040
Flowed with sheet
Flow numbers are
Lift Intake Exhaust
.200 153 118
.300 212 166
.400 243 183
.500 281 212
.600 293 221
BTW these are CNC'd. We out source our CNC work with the best in the business and then complete the heads in house.
Since we are sort of new on the market(we have sold a number of sets on Ebay) with these, as an introductory offer we are giving a set of ARP head bolts to the first 5 orders placed. All that we ask to place an order is a $500.00 deposit and final payment before shipment.
Also add any Comp Cams custom grind cam for only $350.00
Add Comp Cam Chromoly Pushrods for just $110.00
We have a guy in Texas(owner of Torquecentral.com) making 393rwhp and 385rwtq with these heads and a LPE GT2-3 cam(207/220 .573/.580 117.5LSA) through a A4 with a 3500 stall and running 7.46 in the 1/8th.
Give us a call!
Give us a call!
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
