GP for NX nitrous kit
#30
Originally posted by RTICWOLF
I am not as familiar with these kits, but are they anything like the Zex systems with the NOS metered at WOT over the TPS? I much rather have a controlled release at the right time and with the right A/F ratios when I spray NOS into everything......so, does this NX setup work similar? Is it better than the Zex?
I am very interested in this too, but only if it does what I want it to!! I could care a less what the bottle says!
NOS stands for Nitrous Oxide Systems, which is a company that sells nitrous kits among other things. N2O stands for nitrous. Big difference.
The ZEX kit can NOT alter the spray of nitrous/fuel for A/F ratio, as it has no way to meter that. It just adjusts the fuel spray based on bottle pressure. The TPS thing is a joke; is there really any reason why you would want to spray other than at WOT (and spraying in closed loop where the motor is at ~14.4 a/f isn't a good idea). A bottle warmer, WOT switch, and proper jetting are a better way to do this IMO. Venom sells a kit using the factory O2 sensor to monitor a/f ratios, but relying on the factory narrow band O2 for A/F at WOT is playing with fire. The local people I know that have used this kit haven't been very pleased w/ it, especially for the money.
