GMMG GP is a GO!!!!!!!
Originally posted by bluecmaro96
why would you want a raspy crappy sounding exhaust? if you want annoying rasp you should have gotten the crapply loudmouth, i checked mine out and its not touching anything and im still getting that sound that sounds like a heat shield rattling/buzzing, i looked as best as i could around the heat shield that is in the rear of the car right above the gmmg mufflers, i dont see it touching but the noise is annoying, it goes away if i get on the gas pretty good but at idle or under 25 it makes the noise
When did you listen to it? I can tell you that from the inside its not that loud, and having someone rev it while its parked isnt that loud. But when my g/f made an errand one day and drove off, it sounded completely different then I thought. It was much louder and I heard her down all the side streets for quite some time. Bear in mind this with stock catfoward.
-Dustin-
-Dustin-
Mystery Z28
Oct 20, 2002 11:35 AM
