Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Give your Camaro the right stance with Lowering Coilover Kit: Top Options
Old Aug 25, 2021 | 07:50 AM
CARiD's Avatar
Former Vendor
Give your Chevy Camaro the ability to tackle just about any corner with great confidence without sacrificing ride quality by adding a new lowering coilover kit! Once installed, the transformation from your factory or current aftermarket suspension setup will have you thoroughly impressed.
This performance upgrade allows you to lower your Camaro’s center of gravity, which improves handling around tight corners. It also gives you better adjustability and reliability without sacrificing ride comfort. In our today's write-up, we've rounded up the two most popular lowering coilover kits for the 6th gen Chevy Camaro.
If you want to drop your ride and raise your handling performance, any of these options will get the job done!
Bilstein® - 0.4"-1.2" x 0.4"-1.2" B14 Series Front and Rear Lowering Coilover Kit
https://www.carid.com/bilstein/front...47-280502.html
Features:
  • Monotube internal design
  • Threaded body adjustable range of 20 mm at both axles, while installed
  • Road-tested by BILSTEIN under motor sports conditions and fine-tuned
  • Spring plates and lock nuts made from a special aluminum alloy
  • Surface coating using Triple-C-Technology® for long-lasting corrosion resistance
  • Round threads for ease of adjustment
  • Quality sport springs made from highly durable material
  • BILSTEIN gas pressure technology
  • BILSTEIN mono-tube/Upside-Down technology, made in Germany
  • German TÜV certificate
Yellow Speed Racing® - 0"-3" x 0"-3" Dynamic Pro Sport™ Front and Rear Lowering Coilover Kit
https://www.carid.com/yellow-speed-r...cv-dps007.html
Features:
  • 33-Way Dampening Adjustable
  • Newly Improved Rear Dampening Adjustment Method
  • Spring Bearing Top
  • Monotube Internal Design
  • Pillow Ball Upper Mount With Adjustable Camber Plate
  • High Rigidity Steel Spring
  • Adjustable Spring Seat
  • Full Length Adjustable
  • Lower Locking Collar
  • Developed Damping Oil
  • Aluminum Upper Mount
  • Wave Alloy Steel Thrust Washer
Jul 2, 2013 08:34 AM
6SpdLT1Z
Mar 5, 2007 11:33 PM
ArizonaZ
Aug 19, 2005 03:12 PM
auto-Xer
Dec 4, 2002 04:46 PM
Chrisbequick
26
Nov 20, 2002 03:07 PM
