Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Free Adjustable Master Cylinder when you purchase a RAM VDS System , a $160 value !!!
Old Apr 29, 2004 | 02:30 PM
New Era's Avatar
Pictures of these items can be seen on our website at www.neweraperformanceparts.com . This special is only good on the LS1 systems and will be ending May 7th next Friday .
Comes with a free adjustable Master Cylinder , limited time offer !!!!
In drag racing, the clutch acts as the traction control device for the car. The clutch system applies stored energy to the rear wheels during the launch. To obtain optimum clutch performance, you must have enough flywheel inertia to get the car moving and enough clutch clamping pressure to accelerate the vehicle without spinning the tires. To achieve consistency, the clutch pressure must remain constant over time, allowing the car to perform to maximum potential. The RAM VDS system is the only diaphragm clutch that allows you to set up and maintain the clutch pressure.
VDS clutch systems come from the factory with either steel or aluminum flywheels, and include the RAM 300 series organic disc. 300 series discs feature our eight spring hub with urethane encapsulated springs, and steel backed organic facings. The VDS system can be upgraded with either the 900 series sintered iron or 6000 series bronze metallic discs through your RAM dealer.
There are several key features of the RAM VDS clutch system. The clutch is set up with maximum clamp pressure from the factory. Stock and aftermarket pressure plates are set up so that the maximum plate load occurs after the clutch begins to wear. RAM VDS is designed so that the clutch pressure can be restored as the clutch disc wears; oem and other aftermarket units lose pressure as wear occurs. The VDS clutch pressure can also be reduced if the application dictates less pressure is necessary to control tire spin at launch. The VDS clutch system is designed to be user serviceable in the field. Both the pressure plate and the steel insert on aluminum flywheels are replaceable. Combining this with a new RAM clutch disc makes rebuilding your clutch a snap!
All RAM VDS clutches are SFI certified for competition in vehicles running 11.99 or quicker in the quarter mile. Because the VDS system is designed for racing use, it is sold without warranty. This kit comes in two versions , the street/strip version which will cupport 550hp and the strip version which will support 700 hp .
Thanks ,
Mike
sales@neweraperformanceparts.com
585-865-1832
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Jan 21, 2015 10:11 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
siguy
Nov 27, 2014 10:07 AM
