Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
Dennys Nitrous Ready Driveshaft... any vendors?
Old May 22, 2006 | 06:05 AM
bowtiepwr's Avatar
>So I need a drive saft any one else...?
"DENNY'S STRONGEST and BEST DRIVESHAFT assembly. We call this one NITROUS READY because it was specifically designed to handle the massive power generated by using a bottle.
Racers worldwide have proven the benefits of this shaft in all out competition. It’s at home on the street and at the track. Comes complete with 1350 SERIES transmission slip yoke and solid body u-joints or we can build it with your own 1350 series slip yoke if you already have one.
We build this shaft to do what it takes to keep it all together, especially if you are using Nitrous, a manual transmission or have a heavyweight vehicle.
IF YOU EVER TWIST THIS TUBING OR BREAK OUR WELDS...WE WILL REPLACE THE ENTIRE DRIVESHAFT FOR FREE.
Nitrous is not the only reason for owning the best. For those of you who require the ULTIMATE STRENGTH and RELIABILITY from your driveline ...THIS IS IT.
With this shaft you will be able to run with confidence knowing that it will deliver all that horsepower and torque to the rear end smoothly and efficiently without the worry of breakage or the loss of valuable time due to vibration. Vibrations slow you down and destroy more parts than you can imagine. Besides, anything that vibrates, is really annoying especially on the street.
Built with the virtually indestructable 1350 series components for super long life and trouble free operation. Also if you are planning on adding more horsepower or traction in the future this shaft is the best choice. You won't need to buy another shaft later.
Each shaft is built with meticulous attention to detail. Each shaft is HIGH SPEED BALANCED then TESTED on special equipment to be sure it will run the rpm that you require. If it does not pass this test it doesn't get shipped out. No guess work here...we know what it will do for you because of this final test.
That is why a DENNY'S DRIVESHAFT will perform BEST in your application.
All NITROUS READY shafts come with our FREE LIFETIME LABOR for most any maintenance or alterations needs. Please see the LIFETIME LABOR section for details."
http://www.dennysdriveshaft.com/html/nitrous_ready.html
Jeff1904
Jun 5, 2016 05:00 PM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
95blkss
Sep 22, 2015 03:18 PM
ChrisFrez
Sep 9, 2015 06:52 AM
