12 Bolt time again???
It's going to be a little while if your looking for a Strange 12 bolt with the Super Strength posi. That differential is on backorder so any new rears ordered with that set up won't be able to ship until the end of next month. Rears with the standard posi can go out quicker.
Tom
Tom
So you guys won't mind waiting a little for the Strange? If not I can get your orders in line for the batch of Super Strength posi units that become available the end of next month. Rears with the standard posi can ship sooner. These rears are sent complete so they are ready to be installed. I believe the Mosers require assembly before installation.
I'll work on pricing tomorrow if you guys are interested.
What we could do is offer these for $2129.99 for the next couple of weeks. This will save you $170. off of the regular retail. The sooner orders are placed the sooner we can get them in line to be built. Most of them should be able to be built towards the end of March.
PRG210
Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10 $2129.99
PRGOP8 Upgrade to US/Strange 33 spline Super strength posi-unit (w/o reluctor ring - ABS on side of pumpkin) $145.00
PRGOP14 Upgrade to US/Strange 33 spline Super strength posi-unit (w/reluctor ring - ABS on top of pumpkin)
$145.00
PRGOP10 Upgrade to aluminum support cover $115.00
gmbbp
Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings.
$229.99
Thanks,
Tom
PRG210
$145.00
gmbbp
$229.99
Thanks,
Tom
