Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
1.6 Rr Gp?
Old May 3, 2004 | 08:27 PM
  #16
darthrug's Avatar
can someone explain the difference between self aligning rockrs and non self aligning ones to me?
Old May 4, 2004 | 05:45 AM
  #17
Demon SS's Avatar
checked on the pricing for Harland Sharp's and unless I get orders for like 25 sets I can't compete with JEGS and Summit's pricing. I'll see what I can work up on pricing with Comp Cams stuff.
Old May 4, 2004 | 04:49 PM
  #18
skisax80's Avatar
ah i see. well keep us posted!
Old May 4, 2004 | 08:54 PM
  #19
hsyr's Avatar
What about 1.7 rr's with all the goodies to make them work? Anyone else like that idea better than 1.6s?
Old May 5, 2004 | 01:11 PM
  #20
krispy's Avatar
yes, im looking for a good price for 1.7RRs w/springs&guideplates
Old May 5, 2004 | 09:56 PM
  #21
darthrug's Avatar
i dont think 1.7 will work on a lt1
Old May 5, 2004 | 11:43 PM
  #22
krispy's Avatar
yea they do, just not with most cams, mostly will only work on the stock cam, which i plan on retaining
Old May 6, 2004 | 12:01 AM
  #23
darthrug's Avatar
how do you find out if they wont work with a cam? i want to cam my car eventually
Old May 6, 2004 | 12:26 AM
  #24
krispy's Avatar
to figure out lift at the valves take the current lift @ 1.5 RR, and multiple it by (1.7/1.5), that will give you the new lift
then there are a few limiting factors to the lift:
A. Can your valve springs safely handle the lift, springs have a max rated lift and their life is reduced if near or past it
B. Max lift supported by the heads, the stock heads support I think is about .600-.650" lift (correct me if im wrong)
the higher ratio roller rocker will put more stress on the valve train, so when most guys go w/ larger cams and small rocker arm ratio to reduce the stress
Old May 6, 2004 | 08:14 AM
  #25
skisax80's Avatar
ok.. so what if i am getting a 224-330 cam, with springs, retainers and locks, im getting it from a guy on this site, do i need 1.6 or 1.7 rr? people have been telling me 1.6
Old May 6, 2004 | 09:00 AM
  #26
darthrug's Avatar
1.6 is what you need. wheather you could use 1.7 or not i dunno but using 1.6 would not be the wrong choice
Old May 6, 2004 | 02:45 PM
  #27
skisax80's Avatar
so do i need 1.6 self aligning or non selfaligning, i was told non,but only because u get a little better performance... but if thats the case, what other parts would i need to use the non self aligning, and how much does that stuff cost?
Old May 6, 2004 | 04:23 PM
  #28
darthrug's Avatar
self aligning or non doesnt matter. you will need springs and retainers for either. i think thats it. depending on the size of the cam though you will want lifters and hardened pushrods and prob guide plates.
Old May 6, 2004 | 05:32 PM
  #29
skisax80's Avatar
hmmm i see..... so basically, its my choice? do i HAVE to get hardened pushrods or will the stock ones work, this cam i am buyin the guys is throwing in the springs, retainers and locks, he told me what kind, but i forgot off hand...
Old May 6, 2004 | 06:00 PM
  #30
krispy's Avatar
93-95 LT1s came with hardened pushrods, the others didnt
if you change to 1.6 RRs you can get the LT4 springs if you dont have above .550 lift
if above that get an appropriate set of springs springs (check thunderracing.com for part numbers)
You can retain the stock retainers but getting a new set of locks wouldnt hurt as you might accident drop a few into the engine bay.
Your lifters should be fine too unless you are going with a big cam, so check to see what would be recommended with the cam you chose
Also when changing valve springs changing the valve seals is cheap and easy maintainence
