Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
$250.00 off Strange 12 bolt rearends!
Old Sep 21, 2005 | 11:45 AM
tbyrne's Avatar
We are offering $250.00 off of the Strange 12 bolt rearends through Monday, October 10th. The discount can be taken off of the prices listed below -
PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2469.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2469.99
R5206 Upgrade to aluminum support cover $114.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will need to send in your backing plates along with your axles so Strange can use the reluctor rings. $229.99
gmbbpcore Options: If you can't have any vehicle downtime we can charge you $229.99 for a set of backing plates and send them to Strange to be build into your rear. After your 12 bolt is installed you'd send your stock backing plates to us and we'd credit you $175.00. This option is only available if your car does not have traction control or the ABS at the axles. The backing plates are only required for 1998+ cars.. $229.99
Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
Old Sep 21, 2005 | 04:26 PM
ulakovic22's Avatar
Re: $250.00 off Strange 12 bolt rearends!
Very interested, what is the turn around looking like?
Old Sep 21, 2005 | 04:29 PM
tbyrne's Avatar
I can get an update tomorrow. They were running about 4-6 weeks out.
Old Sep 22, 2005 | 08:50 AM
chrism400's Avatar
That deal seems... well, Strange.
Old Sep 22, 2005 | 09:31 AM
Cmr0z28's Avatar
My bank account is on its knees begging for me to resist this deal.
Old Sep 22, 2005 | 09:38 AM
Cmr0z28's Avatar
How much would it cost to ship one of these to 34990?
Old Sep 22, 2005 | 07:12 PM
tbyrne's Avatar
Strange is running about 6-8 weeks.
The rears are shipped freight collect so we don't have an exact $ amount. Most are usually in the $125. - $200. range.
Old Oct 1, 2005 | 02:00 PM
CreatiVe2's Avatar
6-8 weeks before delivered?
Old Oct 3, 2005 | 01:12 PM
85mikeTPI's Avatar
Are the only rears included in the GP listed in the announcement, or
could others (3rdgen full setup, or housing pkg?) be included also?
thanks
mike
Old Oct 3, 2005 | 07:30 PM
Mr.Whitey's Avatar
Does the 3 channel ABS unit come w/ the mounting plates or is the OPRG 12 option additional ? Shipping to 19518?
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
SABLT194
Aug 21, 2002 07:45 PM
SABLT194
Aug 3, 2002 09:33 AM
