who locally sells 160 degree thermo's?
while my car is in 10 different pieces i'd like to replace the stock thermostat while i'm in there... that and the old one is not in such good shape. who locally sells these things for our cars?
1995 Camaro z28
second time to the track in high humidity / temperatures (stock):
1/4: 13.9 @ 98.82 w/2.092 60'
1995 Camaro z28
i looked all over for one when i needed it. never found one for an lt1...ended up ordering from summit.
ARREST-ME RED 96 Z-28, M6...stock for now...but i've only had it three days...1st mod on day 4! TB airfoil...NOW...G2 CAI(modified), K&N, MagnaFlow w/ cutout(closed of course), maf ends, ?cags?, UD pulley, TB bypass, 160stat, SLP fan switch, SLP air temp module, MSD 6A, Hurst(SS donation)w/Lou's SStick and Proform Shiftlight, BMR lca, phb and stb, 32/21mm sway bars, ES TA mount
FOR SALE:SLP afpr, Hypertech PTM, stock z28 sway bars
I got mine threw summit, I remember Autozone selling "low temp" thermostats, cuz I bought one for my girlfriends cavaleir when I flushed the coolant. I don't think it ws 160, but I am pretty sure its lower then stock.
personally 160* stat and watter wetter are great, cut my engine temps in half on my little 3.4L.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
AIM: MustangEater82
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
oh well, i just put the old one back in. maybe i'll order one tomarrow and put it in next weekend when i take off my throttle body looking for that damn oil leak.
i'm just happy my car is running
anyone got an extra working low coolant sensor laying around?
1995 Camaro z28
1995 Camaro z28
