Stock stuff getting trashed unless claimed...
What are you up to now Brett lol?Are you making a pump powered crankcase vent system? hehe I made one out of my stock air pump..seem's to help a little.and a little more peice of mind on my part knowing I have negative crank case pressure rather than positive
I have a window switch to activate 3k rpm untill 6700..it's pretty sweet!
carter
I have a window switch to activate 3k rpm untill 6700..it's pretty sweet!carter
CARTER, you guessed it. I'm gonna seal the motor up and put a vacuum purge on the intake valve. Then I'm gonna run one air pump to each valve cover. Someone on another board managed to get 13" of vacuum (you don't want any more, oiling problems) which increased his hp by 4.7%. He works @ a dyno shop somewhere in virginia. That was on a 396 w/ something in the area of a cc307ish cam, N/A
Mr. T, I'll call you today. When I come pick up the pump, maybe I can grab the rachet and swap it out for you the next day I work.
stockssn2o
May 25, 2015 08:54 AM
