South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
speedo and shift problem
Old Oct 4, 2004 | 08:05 AM
gol10dr's Avatar
I was cleaning my car yesterday and used some Engine degreaser and cleaner to clean the engine area. I have a Jet SCU 2000 in the engine compartment. When I started up my car to run an errand, the speedo isn't working(won't move) and the car doesn't shift out of second gear (the 1st to 2nd shift only happens after it hits 5500 rpms). I put my scan tool on the car and it pulled a 502 code which is the vehicle speed sensor low voltage. Is it because I got the SCU wet, or just a fluke that the VSS went bad.
Old Oct 4, 2004 | 01:29 PM
gol10dr's Avatar
Re: speedo and shift problem
Anyone?
Old Oct 4, 2004 | 04:39 PM
'94 Bad A Z28's Avatar
Did you check ALL your fuses!!!! haha
Old Oct 5, 2004 | 06:28 AM
gol10dr's Avatar
Funny, But Yes I did. One of the first things I checked. And I did pull each one out to make sure they were in working order..
BigWil
Mar 29, 2015 12:24 PM
blac94Z
Feb 10, 2015 11:02 AM
97SSdude
Dec 31, 2014 07:43 PM
tds1213
Nov 27, 2014 12:55 PM
Jul 4, 2005 05:00 PM
