South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
qtr mile times
Old May 26, 2004 | 10:17 PM
camzaro28's Avatar
qtr mile times
ok osw is really hard to hook up.
1st run 2.540 60',,,,,14.738@96.48 in D
2nd run 2.546 60',,,,,14.966@95.64 in OD
3rd run 2.316 60',,,,,14.644@95.89 IN OD
4th run 2.279 60',,,,,14.628@95.66 1 2 D
i thought lt1 ran a lil quicker then that. hopes for 14 flat are gonna be a while. some of the quicker camaros were barely gettin low 14s,,hmmm u got me.
very end of the night one of the lt1s were gettin trailered by a 4 door dodge. camaro got loose some how and slammed into the back of the dodge.. sad sight
well oneday i will get into the 13s
Old May 27, 2004 | 06:34 AM
teke184's Avatar
what was the humidity and temp? how bout the short times?
those 3 things combined and can lead to a very poor showing.
Old May 27, 2004 | 09:54 AM
IROCBeerBeer's Avatar
2.5 60' times go alittle easier off the lineand try not to spin
Old May 27, 2004 | 11:31 AM
MustangEater82's Avatar
yeah really need to bring that 60' down...
commone drag racing rule of thumb, every .1 in the 60'= .2 in the 1/4 mile.
Makes you feel any better been cleaning up my room and found a timeslip from 1999 from in my 2.8L v6. I think this was my first time out to the track.
February 26th, 1999
R/T 1.200
60' 2.775
330 7.811
1/8 11.936
mph 60.73
1000 15.435
1/4 18.452
mph 74.46
This was done in my 1985 2.8L Camaro, A4, pretty sure it had 3.23s, I had a rigged up Ram air, ignition coil, plugs, wires, and exhaust.
http://images.cardomain.com/member_i...05_14_full.jpg
http://images.cardomain.com/member_i...05_23_full.jpg
I think my best time was about a second faster in that car. Goes to show why you don't go to the track once and be assume thats all your car will do.
But dang a 2.775 60' and people used to tell me you cannot spin the tires in a 2.8L automatic v6
Old May 27, 2004 | 12:35 PM
badblackta's Avatar
yeah biring your short time down and your time will be alot better. Your first investment should be in some sticky tires like et streets or drag radials, that will bring your time down in a hurry.
Old May 27, 2004 | 02:38 PM
heck I would even hold off on those, and just hit the track 2-3 more times and see what you can do with different track prep and more practice...
Shaen went with his turbo v6 bird recently ahd he had lots of traciton problems and he usually doesn't have too many.
Old May 27, 2004 | 03:37 PM
Caps94ZODG's Avatar
and switch those firestone firehawks to the rear..better tires than the ones in the rear right now...
Old May 27, 2004 | 04:28 PM
SFB767's Avatar
You'll get better times man, just practice. LT1s are strong cars and you should be able to pull off high 13s if you can drive it like an expert.
That's about right, I think I may have a little exception though.
Best I did my first time at the track (OSW) was a 14.0@102 with a 2.3 60'.
Last March I went 13.5@105 at BMP with a 2.2 60', what an improvement. Maybe it has better prep.
If I can get my 60' down to say a 2.0, what do you think I'm good for?
Old May 27, 2004 | 06:48 PM
camzaro28's Avatar
yeah my last run with the 2.2 60' was ithe opposite the 3 other passes. yeah the tires on thre now are a lil dry rotted but have decent anount of tread left in em (dry rotted cuz the car hasnt been driven, in waht looks to be 2 years) since the car hasnt been driven in so long maybe it needs a tune up and oil change!! that would probably help.
even when i eased in to it and went i to it at 20-25 it would still spin like crazy, next wednesday i will flip the tires around and seee what happens.
hope to see yall out there
Old May 29, 2004 | 07:35 PM
86 IROC's Avatar
Right off the bat, the weather right not really sucks for racing. And, like everyone else said - 60' times are horrible. Cooler weather, fresh radials, and a good tune up should put you in the low 14's at 98+ MPH.
Trust me on the weather... I'm so close to a 12.99 that I can smell it. What I wouldn't do for some colder temps right about now.
Old May 30, 2004 | 01:09 AM
camzaro28's Avatar
ok i got some ?s for u guys. i dont know much about tires, so what is a good tire for the street and track that will last a decent amout of time? and on my last camaro i went with 2 inch wider tires on the rear would that be a good idea to do again? doing that i know i cant rotate them whe needed. i will jsut have to uy more tires. ay suggestions please. thanks
Old May 30, 2004 | 06:12 AM
SFB767's Avatar
My tires seemed to be pretty good at the track and on the road in wet conditions. I've also ran over some pretty hairy stuff in the road and the tires didn't even puncture. They lasted me 23K miles (don't know if you think that's a long time-I don't) and I just put my second set on last Saturday. They're a great all-around tire.
Old Jun 2, 2004 | 09:58 PM
camzaro28's Avatar
ran it 6 more times tonite. not much better then the last time out. car needs a tune up, has lagg when it starts getting into higher rpms. my average trap speed was 94.5 mph.. and times were avg at 14.7. slower then last time out. iwill post times up soon.
any mod that would almost gaurantee me to get low 14s possibly high 13s?? please tell me
Old Jun 2, 2004 | 10:05 PM
camzaro28's Avatar
http://us.f2.yahoofs.com/bc/40b3a4e2...qkpvABB5kGAp6x
time slips 3 of 6
Old Jun 2, 2004 | 10:06 PM
86 IROC's Avatar
The weather sucks for one, that's part of it. You'll be about .2 faster in colder weather. The main thing now is good tires and a thorough tune up. Throwing mods at a car that isn't in a good state of tune is assed backwards.
