South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Paging MustangEater
Old Feb 17, 2004 | 11:17 AM
gol10dr's Avatar
Paging MustangEater
I was wondering if you could possibly give me a hand changing out my rear sometime, You'd be an asset since you've done it before. I finally have calipers coming from Billy Graham so they will be here tomorrow. Email me at Sarkj@ocps.net
Old Feb 17, 2004 | 11:21 AM
2002Z28SSConv's Avatar
Billy Graham
Old Feb 17, 2004 | 10:06 PM
MustangEater82's Avatar
Re: Paging MustangEater
Sure I might not know much about puttig the calipers on but I have pulled the rear and put it back on... actually more then once
I just need to figure out a time, got school/work.
Old Feb 18, 2004 | 06:31 AM
gol10dr's Avatar
the calipers are pretty much straight forward to put them on, I just need help putting and taking off the rear.
Old Feb 18, 2004 | 07:24 AM
darkoverlift's Avatar
So you need more of a supervisor who has done it before in-case you run into little quirks because removal should be easy...
Old Feb 18, 2004 | 08:39 AM
'94 Bad A Z28's Avatar
I was just thinking about this, what are you going to do about reprograming for the gears?! Also, did you change the rear fluid and add the posi additive yet? If not you really need to do that and it is a lot easier to do with the rear out of the car.
Old Feb 18, 2004 | 08:42 AM
Ya I helped him on that.. He tosed in new Amsoil Synthetic fluid and gm posi additive.
Old Feb 18, 2004 | 08:43 AM
Old Feb 18, 2004 | 08:44 AM
Boy did that gear oil stink.. It stunk my garage up, and some of the inside of the hosue. I had to move the rear to the back yard it was so bad...
That still leaves the question about reprograming for the gears?!
Old Feb 18, 2004 | 08:45 AM
He is ordering the Jet Scu 2000. It will correct up to two gear changes so he can go as high as 3.42 if he wants and the shift points and speedo will be correct.
Old Feb 18, 2004 | 08:46 AM
Lol.... My bad!!!! I tried to do it for him. But I waited too long and didn't have time to go get the right tool to get the plug out, lol.
Old Feb 18, 2004 | 08:47 AM
Fatdog2
Sep 16, 2015 11:04 PM
cmsmith
Aug 27, 2015 06:37 PM
97blackformula
Aug 27, 2015 06:02 PM
WPHIG2
Aug 27, 2015 06:37 AM
cmsmith
Aug 20, 2015 07:57 PM
