South Atlantic Delaware, Florida, Georgia, Maryland, North Carolina, South Carolina, Virginia, and West Virginia
Need a rear
Old Oct 2, 2005 | 12:27 PM
louvit's Avatar
Need a rear
I have a good 10 bolt with 373's but I guess the clutches are gone (1 wheel burns) I'm am looking for a posi unit or maybe a complete rear with 342's or 373's...Problem I cant p/u. No truck or anyway to come get it, show me what you got
Old Oct 2, 2005 | 06:08 PM
MustangEater82's Avatar
Re: Need a rear
Make sure to post up if you get a complete 3.42 rear, might be intersted in your 3.73 rear, even with bad posi.
Old Oct 2, 2005 | 06:11 PM
louvit's Avatar
Re: Need a rear
thanks man, but I guess you just did that for me....lol
Old Oct 6, 2005 | 10:53 AM
louvit's Avatar
Re: Need a rear
No one has a rear in Fla? lol
Old Oct 6, 2005 | 11:13 AM
Re: Need a rear
This guy seems to sell used f-body and mustang parts in Orlando area
http://motors.search.ebay.com/_W0QQs...oastmotorworks
and these guys are down near miami
http://www.tacreationsusa.com/
Old Oct 7, 2005 | 02:29 PM
2002Z28SSConv's Avatar
Re: Need a rear
Ebay Item number: 8004915389
Old Oct 8, 2005 | 10:53 AM
louvit's Avatar
Re: Need a rear
nice one, will this bolt in with no modifacation in a 93 z28? I know the e brakes are different but if i use my rotors and calipar it should be fine...correct?
Old Oct 10, 2005 | 06:43 AM
Re: Need a rear
The only differenced, as far as I can recall, were gear ratio (for speedometer concerns), ABS / traction control (2 signal / 3 signal I think it's called) and drum to disk. It WILL bolt up but you might have problems with the other little stuff. I'm sure you can find a lot more info on this in the tech forums with the search feature.
Old Oct 10, 2005 | 06:48 AM
louvit's Avatar
Re: Need a rear
I heard that i cant use lt1 brakes due to the backing plates or something. I dont have traction control so thats not an issue, I almost hope I get outbid. I dont what to hassle with backing plates and all and the e brake is another issue.. I thought it was a direct bolt in...maybe i can just pull the posi unit out if it and just use that..
Old Oct 10, 2005 | 07:13 AM
Re: Need a rear
really? because I was eyeballing it, then noticed you were bidding on it, so I backed off.
Old Oct 10, 2005 | 07:21 AM
louvit's Avatar
Re: Need a rear
hey man thanks for not bidding for me, and thanks again for bidding...lol As I said I may be wrong. but it's not a direct bolt in and my skills lack some...lol i will just look for a posi unit and have it installed, if I can't get a direct bolt in
Old Oct 11, 2005 | 01:38 PM
muscle cars's Avatar
Lightbulb Re: Need a rear
I have a 2.73 posi rear from a 1993 Z-28 that has approx 35,000 miles on It and it has been in storage. The rearend comes with a pallet for easy delivery and ancillary parts. Let me know if you would be interested. You can rent a U-haul truck for $19.00 and I can help you load and unload if needed. Raul 407-365-2950
Old Oct 11, 2005 | 06:50 PM
louvit's Avatar
Re: Need a rear
no thanks I need a 3 series carrier
Old Oct 12, 2005 | 09:19 PM
cad78's Avatar
Re: Need a rear
I got a complete rear from an LT1 Fbody laying in the back yard. Supposed to be 3.42s. You can have it, I just bought it for the rear brakes. I threw away two complete Ls1 3.42 rears after I stripped the brakes just a few weeks ago
Old Oct 13, 2005 | 04:23 AM
louvit's Avatar
Re: Need a rear
wow thanks Now I just got to figure out a way to pick it up in a camaro..no truck avail.... pm me your address so I can see how far from Brandon you are Maybe i can pay someone to pick up and deliver to me
