Need help solving a bet! What is faster stock down the track?
Depends on the launch. Stock for stock I think the M6 has an advantage, because they can "stall" the motor before they launch. Only so much you can do with the stock converter.
also is 94 the year with more for acceleration gear ratios on the M6 tranny, or was that only in I think 93s.
1994 Medium Quaser Blue Camaro 3.4L V6 w/ 5-speed
Homeade CAI with a huge K&N cylinder filter, Single outlet Flowmaster with resonator, Accel 8mm ignition wires, Splitfire plugs, 3.42 gears and posi off a 97 WS6, 1 piece steel driveshaft, Converted to 4-wheel disc brakes, 1LE transmision mount, 1LE sway bars, Prothane bushings and endlinks, BMR Strut tower brace, ASP underdrive pulleys
Lightest Weight W/out driver: 3160
15.696@86.22 with a 2.214 60'!
Best R/T .507
Best 60' 2.106
Father's Stock 2000 Navy Blue Camaro 3.8L V6 w/ 5-speed
15.875@88.25 With wheel spin in 1st
AIM: MustangEater82
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
IMO, could go either way and it'll be too close to give one or the other a hands down win. So, nobody wins the bet
Brent Franker * Main Page
94 Vortech Z28 * 96 Z28 SS #1655
4th Gen Appearance Modification Guide
F-Body Install & Fix-It Guides
I would say that it's all dependant on the drivers. But if you have some top-notch drivers that can drive both cars to the limit i would say the M6 just because you can control the engine speed. Just my 2 cents...
~Wilson........
Smoked out Black 93 Z28
EGA behind passenger window...
Sleeping Midnight Blue 89 GSX-R 750
~Wilson........
Well M6 you also have the ability to power shift, and keep the revs up for a split second between shifts, and in my opinion you can shift faster in an M6 then in a stock auto.
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
Assuming all things were equal from the factory (eninge HP and such), and discounting driver skill, traction, then I would figure the 6M to be quicker due to less HP lost through the drivetrain and the 3.42 gears versus the 3.23 for the auto and overall vehicle weight.
Now that is a lot to have happen. In the real world I would bet on the auto unless the driver of the 6-speed is very good.
Later ... Larry S.
'95 Trans Am - Powerdyne
11.874 @ 118.92 MPH
Later ... Larry S.
11.874 @ 118.92 MPH
Guest
Posts: n/a
I have to disagree with that last statement. Frank(96blackss) can shift faster than most auto's, trust me on this one. I have never seen anyone shift a manuel as fast as him, anyone who's ridden with him knows what I mean
But, I'd have to say that with a good driver the M6 is gonna win, but if the driver is anything less than good it's the auto's race.
Camride ~ 1994 Bright Red Camaro Z28 A4. For sale.
Camride's Page
But, I'd have to say that with a good driver the M6 is gonna win, but if the driver is anything less than good it's the auto's race.------------------
Camride's Page
Agreed with the staement above, I shift faster then hell to, with a power shift you get a split seocnd spike in the RPMS too, not worth much, but engines, and weight being the same may make the difference.
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
Best R/T .507
Best 60' 2.106
AIM: MustangEater82
FYI- the 93's were the year for the good trannys with the close ratios. 94+ came with taller ratios.
Yeah it al depends on both drivers.
The auto could be dumb and blow it at the line just as the Manual driver too. Most likely the Auto car would launch better by around 2 tenths, but the Manual car would make up that time by the end of the 1/4 mile, that is if the driver is GOOD.
So have the guys do some runs with other people and see how they do at the line. Then you can do the bet.
my93z286spd@yahoo.com
93 Z28 M6
01 WS6 Trans Am A4
91 Talon TSi AWD Turbo
89 Suzuki GSX-R 750
Brevard Muscle Car Enthusiasts Founder
www.gmmuscle.cz28.com
Street Lethal Performance & F-Body Organization
www.streetlethalperfomance.com
Page w/ Mods & Movies !
www.93z286spd.cz28.com
93 Z28 M6
01 WS6 Trans Am A4
89 Suzuki GSX-R 750
Just a thought on an auto shifting as fast as a 6 speed. Remember to factor in the PCM into the equation since it looks for RPM's, speed, and load to determine when to shift. Granted most of this is in microseconds but they still have to all meet the criteria for a shift before the PCM directs the shift and it is then executed.
For example. My T/A has a built tranny and lots of special items. I have it programmed to shift at 5400 RPM. In looking at logged runs the shift actually happens at 5800-5900 RPM due to vehicle acceleration being faster than the PCM reading all parameters and actually completing the shift. If I program it to shift 6100 then it hits the rev limiter at 6700 before it shifts.
For the most part (on "equal" cars) the determining factors will be traction (60' times) and vehicle weight. Unless of course the 6-speed drivers is pretty bad at shifts or misses a shift.
Just my .02
Later ... Larry S.
11.874 @ 118.92 MPH
Just my .02
Later ... Larry S.
11.874 @ 118.92 MPH
NewsBot
Dec 21, 2014 06:55 PM
