Longtube headers and custom 3" X pipe F/S!
ok I am asking $1,200.00 plus shipping...it is for a set of SLP longtubes with a custom dual 3" X pipe and bullet muffler's..also includes the 3" off road Y pipe that comes with the headders in case you want to run the longtubes with your current exhaust...this set up cost's around $1,600.00 to duplicate..Thank's,
Carter
Carter
Going with a custom Turbo kit I am fabricating up as we speak..gunna be fun
T-76 Q Trim single turbo,Aeromotive 2000HP fuel pump,Seimens 95lb per hour injectors, a whole bunch of good stuff... So I cant use the headers or exhaust anymore with the turbo
Later,
Carter
Later,
Carter
Good deal Carter! I knew you'ld see the light
What kind of fuel and timing control are you planning on using?
Also let me know if you haven't bought your turbo parts yet, I can get you a bretty healthy discount on anything Innovative or Precision Turbo.
Hey Chris,
Yeah man turbo is the way to go haha...I am gunna be running a Precision T-76 Q trim and I have dual Walbro 255's in the tank right now.gunna run seimens 72lb injectors..then gunna tweak with edit for a while untill i put the GEN 7 in it...you put a turbo LS1 in the 69?? dudee I gotta see that lol...Later,
Carter
Carter
where did u get your Wiring Harness for the 69' ? Looking for one that will work witha 6 speed , Carter and I are building a sleeper hope fully will be done by this time next year
I would like to see that car also ls1 + Turbo
Later ,
Eddie
....I would like to see that car also ls1 + Turbo
Later ,
Eddie
My harness is a standalone FAST system with the GM cam sensor and a MSD crank trigger, with an EDIST coil driver. It will work with any trans, although it can't lock a converter like a GEN 7 can.
The converter lockup option is pretty useless though, as any vehicle powerful enough to utilize a FAST or GEN 7 will be powerful enough to destroy a 4L60E in no time, so a 400 or 350 is the way to go in automaticville.
You gonna try and keep the AC or go ***** out light weight turbo power?
drptop70ss
May 4, 2015 08:22 PM
racecarz28
Mar 30, 2015 09:55 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
