Cylinder head porting services.
I am now offering Cylinder head porting services to any year/make/and model car..my specialty is LT1/LT4, TPI and Mustang 5.0 liter head's (D80E,E5AE,E7TE & GT-40-P)....These prices are for 5.0 liter mustang's,price for assembled ported Stage I head's are $485.00 complete plus core charge of $150.00..Stage II head's are $595.00 assembled plus core (due to the falling rate of GT-40 head's and limited casting's..there will be no core charge,because I will port your existing casting's).LT1/LT4 head's Iron "from impala" casting's Stage I $575.00 with no core (port existing casting's). Only Stage I is offered at this time for the iron head's.Stage I Aluminum LT1/LT4 head's $575.00 plus $250.00 core charge.Stage II Aluminum LT1/LT4 head's $975.00 plus $200.00 core charge.(LT4 core charge is $450 or I can port your existing casting's).All stage 2 LT1/LT4 head's come with manley race flow valves and comp cam's dual valvespring's..other options available at additional cost.Thank's..if you have any question's shoot me an E-mail Z28VF@AOL.COM
Carter
Carter
Thank's Mike,
I have all price listing's and specifications for stage I & II LT1/LT4 cylinder head's..please E-mail me for all product information including product spec sheet..I can forward you a list of spec's for my stage I and stage II's if you wish..I also offer removal and installation of these and any cylinder head's as well as installation of ALL performance part's.Thank's,
Carter
"Edwards Motorsports"
407-474-1984
Carter
407-474-1984
Hey man... do you know what kind of flow #'s your E7TE's or E5AE's will flow? And what's the difference in your Stage I and II job? What lift would the spring setup support? I'm running a fresh forged 306 with a Crower roller cam and am looking at head options, upgrading within the near future..
How does this compare to your GT40's? Would the core charge cover the GT40s as well as the E7TE castings?
What intake would you recommend with this setup? I have a hogged out stocker right now that I have "worked" on and will be running 150-175 wet shot on this motor through a direct port fogger in the manifold.. hehehe
I have heard of plenty of power being made on ported E7TE's . It can be done..
Sorry for all the questions
Thanks man
Steve
Thanks man
Steve
Hey bro,
Well the stage 1 E7TE & E5AE head's are for minor performance..they are dissasembled,hot tanked,and magnafluxed..then receive a new standard valve job along with new valve giude seal's..then the valve job and bowl's are fully hand ported and blended then reassembled. intake flow's approx 13-15 cfm over stock and exhaust flow's approx 20-22 cfm over stock.These head's retain stock valves and spring's.
The stage 2 is the good stuff
the stage 2's are dissasembled,hot tanked and magnafluxed..then receive a 3 angle performance valve job along with surfacing of the head to increase compression 1/2 a point.Comp cams 987 dual valvespring's for cam's up to .600 lift along with matching retainer's and lock's...the head's then receive fully ported intake and exhaust runner's for optimum result's..there are a number of option's that can be had also..such as manley race-flow valve's stock size or up to 1.94/1.60 then additional port work and epoxy work for even more cfm.those are options though and will of course cost extra..shoot me an e-mail if you have any more questions z28vf@aol.com thank's
there are no official flow number's due to extra option's and customizing for the stage 2's so flow number's will vary with options of course,The gt-40's will only be done by existing casting's..you bring me your gt-40's and I port them..they are getting more and more rare and the demand is going down also, so ford racing is thinking about quiting the production line of the gt-40 "p" head's due to lack of demand,but to answer your question the core charge on the gt-40's can be done..but it will be $270.00 per head because thats the factory pricing you know?...best bet would be to go to a junk yard and try to find some head's off of the v-8 fuel injected explorer and bring them to me as the core or as the head's you would like to have ported.That would save the both of us time and money along with the fact you would have some nice ported gt-40's at a cheaper price
I would actually recomend the production cobra intake or the edlebrock RPM manifold..they would do nicely...thank's again,
Carter
I would actually recomend the production cobra intake or the edlebrock RPM manifold..they would do nicely...thank's again,Carter
Just posting info on the stages of LT1/LT4 head's.
Stage 1 LT1/LT4
1.Hot tank and inspect head's to check for crack's and defect's.
2.Resurface head's to desired compression.
3.Three angle valve job.
4.New viton valve seal's.
5.Hand blend valve job.
Price $575.00 with exchange.
Stage 2 LT1/LT4
1.Hot tank and inspect head's to check for crack's and defect's..
6.Rework valve guides and full bowl porting.
7.Includes manley race-flow intake and exhaust valve's.
8.New comp cam's dual valve spring's.
9.Smooth combustion chamber's for better flame travel.
10.Fully port intake & exhaust runner's while keeping small port volume for better velocity and better mid-lift number's.
Price $975.00 with exchange
Stage 3 LT1/LT4
(coming soon!)
Carter Edwards "Edwards Motorsports"
407-474-1984
Stage 1 LT1/LT4
Stage 2 LT1/LT4
Stage 3 LT1/LT4
(coming soon!)
407-474-1984
Hey chris,
I don't own one..I use bill sternagle's at Champion racing head's inc. in palm coast...SF-600 now,but I think they are getting a 1050 soon that will be cool
all my machine work is taken care of by my local machine shop over here...but I think there is a closer bench than palm coast..let me know if you find one closer because I am kinda tired of driving that far lol..but bill is cool and I will still bring some buisness to him..give me a call tomorrow bro.later,
carter
all my machine work is taken care of by my local machine shop over here...but I think there is a closer bench than palm coast..let me know if you find one closer because I am kinda tired of driving that far lol..but bill is cool and I will still bring some buisness to him..give me a call tomorrow bro.later,carter
oldschool
Feb 9, 2016 09:21 PM
Chris Anderson
Jan 27, 2015 08:30 AM
