[Florida] 2001 Z28 Roller w/ mods. Only needs motor/trans
2001 Z28 Roller. Car is COMPLETE minus a motor and tranny. ECU and all wiring is all there.
- 118k on body. Auto. Cloth. TTOP car.
- Complete wiring harness and correct ECM/PCM
- Very clean exterior
- Taillights are clean. No rust.
- DASH is not cracked
- TTOPS IN GREAT SHAPE with shades
Mods:
- Polished AFS Zr1s (old school style on rear) Fronts are very good and rears are like newish 315/35 17 MICKEY THOMPSONS
- Drilled Brake Rotors in front
- ARP wheel studs in front for skinnies/spacers
- Spohn Lower Control Arms
- Spohn Solid Sway Bar in rear
- Lower control arm relocation brackets
- 1LE Panhard Rod
- SS Springs
- Bilstein Shocks
- Walbro 255 in tank
- 10 bolt
- AAM Cover on rear end
- Autometer Electric Fuel Pressure gauge
- Autometer Electric Trans temp gauge
- Full Triple Pillar Pod
- Gauge bezel where radio goes for two gauges (i have the entire Monsoon system that has been removed)
- -AN fittings and line from hardline on body to rail
Also have the complete stereo. All four speakers. AMP. Monsoon RADIO its all there.
Bad:
- Windshield cracked but its getting replaced
- Radiotor Core Support cut for vertical setup (was gonna turbo)
- No A/C
- Front bumper cut for front mount. Camaro insert covers it up.
AGAIN EVERYTHING IS THERE THAT YOU NEED TO GET THIS THING RUNNING. DRIVESHAFT, RADIATOR, FANS, ETC ETC ETC..
$2800 with the Zr1s
$1700 without the Zr1s but you have to bring your own wheels.
Mods:
- 1LE Panhard Rod
- SS Springs
- Bilstein Shocks
- 10 bolt
Bad:
- No A/C
$2800 with the Zr1s
Re: 2001 Z28 Roller w/ mods. Only needs motor/trans
hey you still have it?....email samsdbest1@aol.com...or reply i'm new to the site..looking for a place to get a roller...if you dont have it help me out ....sam....
