$1,000 4th gen f-body! Doesn't get any better then this!
This car is not wrecked, drove it 35 miles today!
1994 3.4L v6 Camaro 5-speed
Medium Quaser blue.
DriveTrain
-128,600 on the motor, runs fine, starts no stalls, studders, major leaks, good gas mileage, and no SES lights.
-transmission rebuilt last march, currently has problems, won't let you into 2nd, doesn't through you out, just doesn't let you in. Occasionally you can get it in and it runs fine. Tranmission runs fine in all gears.
-rear end was replaced with a stock 10-bolt off a 97 WS6, has 3.42s, LSD, and converted to 4 wheel disc brakes, I also put in a lt1 driveshaft with no vibrations
-Interior, pretty dirty, but dash is fully intact, Needs new bezel from where my radio got stolen, everything else fixable or no problems, steering wheel foam rubber is coming off at top, abotu a 2in, by 2in hole in driver seat, healiner fabric is completely off.
-Paint is not show quality but WAAAAAAAAY above the quality of a $1,000 car. Ask people that have seen it, few dings, some chipping on the nose.
Other misc. car stuff...
-battery and alt are like 1.5 years olf
-new belt and tensions pulley maybe 1 month old
-new plugs and wires, abotu 2 months old
-rear pads are bad, but fronts are good hawks, car outstops my girlfriend's '00 cavlier with 20k on it.
Has Salad shooters, they are pretty clean, no dents, few scrathes, on outer ring.
-CAt is a year old, has a stock z28 ctback on it, gives performance but not loud
-has a cutout, extremly loud All exhaust stuff done last december
Tires should be driveable soon but reccomend new ones, since used tires are being put on the car.
I am going to be busy most the weekend but if you want to see it, and you are in the area, it will be parked out behind the movie theater at Waterford. This weekend, firday 6-12, sat 6-12, and sun 8-6(I might leave early on sat.)
Perfect track car, or with a little work perfect daily driver.
has no options, crank windows that work wonderfully, manual seats, locks, doesn't even have foglamps.
weighted 3160 without spare and jack.
3020, when I pulled hte carpet and seats to clean them thoroughly and ran it at the track that night.
Pictures from SLP day in march...
http://www.mustangeater825.50megs.co...y/DSC00002.jpg
http://www.mustangeater825.50megs.co...y/DSC00032.jpg
Little bit older but a close pic of the front fender
http://www.mustangeater825.50megs.co...aliper%203.jpg
Like the title says $1,000 need more pics I can get them but my camera is not perfect.
Great deal, car can be fixed up and running easily, or ready for an lt1 swap, just need, motor, tranny, pcm, fuel lines and fuel pump, many of done this for less hten $2500, without the rearend and driveshaft. Those are already on this car!
Orlando are preferred.
Medium Quaser blue.
DriveTrain
Originally posted by LPE Z convt
like more pics of inside the car and if you could call me at 765-426-9944 thanks
Originally posted by idlerecords
would you consider miami kinda local? I am pretty interested.
But as of now the front tires I really do not want to drive that far on, but working on a used pair for the fronts.
Either way guy above your post has 1st dibbs.
I know you're busy, but I have cash in hand!
