Why won't my left blinker work?
I checked all the brake light bulbs and they seem to be good and so does the front turn signal bulb. My right blinker works fine but the left one just stays solid. I do have sequential taillights and all the wires seem to be hooked up well and clean. Could it be my flasher module?
Originally posted by notstock4long
I think Shoebox said before that it is the turn signal flasher, I am also have the same problem. Do you four ways, or hazard lights, whatever you call them, still work?
I did not, however, check the third brake light or reverse lights. I did not think that they would affect anything.
A little more info.......Last fall just before putting the car away, my left front driving light (the orange one that stays on when I'm driving) stopped working about 10 different times. It would work and then it wouldn't. I just got the car out a week ago and it's been fine and looks fine.
I'll have to put a different bulb in that one and try it.
I had the same problem. It turned out to be the flasher even though both sides still worked when I turned my hazards on. Apparently, just part of your flasher can go bad. And before anyone gets smart, 94's only have 1.
Originally posted by My95Z
did you check the blinker fluid? gotta have that all the way full
I had a similar issue except mine would do that unless I had the steering wheel tilted all the way up. I had the stalk replaced and it worked fine since then. Just thought I would add that to the mix.
