Clutch Install, Question
Me and a guy are doing my clutch this week, i have the Pressure Plate and the Disk.. what else do i need?
IE. Fluids, seals
all that fun stuff... i know i need my flywheel re-surfaced, but is that it?
IE. Fluids, seals
New throwout bearing and pilot bearing are a very good idea. I also replaced the rear main seal on the engine while I was in there, it's not required but since mine had 50k on it at the time I figured it was a good time to do it plus it's pretty easy with the trans and everything out. Also I drained the trans first when I did mine, otherwise you can have a mess when you start to lower it.
Jul 4, 2005 05:00 PM
Chrisdude
Jul 24, 2002 02:25 PM
