Cheap Upgrades
home-made cold air induction, typcially $75 or so including a K&N filter. or just buy an after market one, used $100-125 and new around $175-200. look into the morosso, lingtfeleter (sp?) or the K&N
throttle body bypass...the 95 might need the hose fitting, i know the 96/7 don't need anything...just reroute the hose. while you're at it a 160* thermostat for $20.
cutout, $35 from summit, and ~$50 to weld it in. or you can get a cheap/used cat back for around $300-400. look into the loudmouth or the hooker
gut the cat, or get an offroad pipe
do you have an M6? if so...i'd get a new shifter...great feeling EVERY time you drive and no missed shifts
just do a search for some of the key words i mentioned...you'll get enough info to keep you reading for a week.
Formula Steve
Sep 19, 2023 08:31 AM
