Is it possible to use just a cloyes chain?
Old Mar 8, 2003 | 06:49 AM
96z's Avatar
96z
In my search for a stronger timing chain I thought about possibly buying a cloyes heavy duty set and just using the chain and possibly the crank sprocket. Is this at all possible or feasable? Arent all SBC chains the same?
Old Mar 8, 2003 | 12:11 PM
Jason Dove's Avatar
The stock LT1 chain and the Cloyes Chain are VERY different. It wouldn't mesh up with the stock Camshaft sprocket.
Old Mar 8, 2003 | 02:12 PM
Dr.Mudge's Avatar
The stock sprockets are not setup for a bicycle style roller chain, they are much, much too wide. No unfortunately not all SBC chains are the same, the cam gear on the SBC chain I believe is larger, but I dont recall details since I dont play with SBC stuff.
Maybe you could, if you felt inclined for a project, find a way to get an SBC setup with cam and crank gears. One word of warning is to look for a ROLLER setup, since a non roller I believe wont have the provission for a cam dowel, and those gears are very hard to drill through, unless you took it to a machine shop you would spend a very long time trying to work with it, and a machine shop will be much more accurate anyway.
Old Mar 8, 2003 | 02:38 PM
96z's Avatar
96z
Darn. Another road block...thanks guys.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
FryedClutch
Sep 1, 2015 08:24 AM
camaro02DK
Jul 5, 2015 09:04 AM
