My oil pressuser seems to low need help?
That seems very low to me. Mine sits between 20 & 25 PSI at Idle. Goes up to about 55 PSI under revs. I'd double check that.
Last summer my Oil pressure read about 10 & then I noticed my stock sending unit was bad. I replaced with an aftermarket gauge & all is good now.
Its not hard to install.
I've never done it on a 94+ car but I think its at the back of the intake manifold on the driver's side?
Mine was way low on the driver's side above the oil pan because I have a 93.
It just screws in. Be careful of the plastic connector on the end. Easy to break in the cold.
Do a search about the OP sending unit & you should be able to find out about the socket that I mentioned. I am sure you can do it without the socket but it is tight back there & may just benefit you.
Good Luck.
