timing set?
Old Mar 5, 2003 | 10:32 AM
94GreenZ28's Avatar
timing set?
Is there anyway to tell if your timing chain set is worn? I have a low rpm stumble and a high rpm miss and I was wondering if that could be a cause. The engine has 70k on it and it pulls hard in the mid rpm range, just has problems down low and up top. I have replaced pretty much every external engine part that would cause that kind of problem. Would a compression test tell if the timing chain is worn?
Old Mar 5, 2003 | 10:44 AM
DaveW 396ci's Avatar
No a compression test wouldn't tell you if it is worn. You would need to pull the timing cover and inspect it.
DaveW
Old Mar 6, 2003 | 03:03 PM
94GreenZ28's Avatar
What are the symptoms of a worn timing set?
Old Mar 6, 2003 | 03:08 PM
joeSS97's Avatar
Take a timing light to it.It should be steady.I doubt that is the problem.More than likely an ignition stumble.A compression test is a good idea though.
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Queens94z28
Dec 20, 2014 09:11 PM
