timing set?
timing set?
Is there anyway to tell if your timing chain set is worn? I have a low rpm stumble and a high rpm miss and I was wondering if that could be a cause. The engine has 70k on it and it pulls hard in the mid rpm range, just has problems down low and up top. I have replaced pretty much every external engine part that would cause that kind of problem. Would a compression test tell if the timing chain is worn?
Jan 23, 2015 01:13 PM
