do the timing cover and rear main seal gaskets need RTV?
hey guys. i did a search but some people used RTV and others didn't, i just want to make sure i do it the proper way. the gaskets in question are the ones that go against the block not the oil seals themselves.
thanks for any help
thanks for any help
Re: do the timing cover and rear main seal gaskets need RTV?
Use gasgacinch to glue the gaskets to the block, then use a thin bead of silicone to seal the cover and the rear seal housing.
http://www.summitracing.com/parts/edl-9300
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
