1997 Z28 Heads/Cam car
Old Mar 19, 2013 | 07:14 PM
LearJet's Avatar
car in sig is up for sale, here is the craigslist cut and paste. Asking 6500.00
Selling my 1997 Z28. Car is red with black T-tops, tan leather interior. List of modifications is extensive. Over 400 HP! Engine has a CompCams 503 camshaft, hardened one piece pushrods with guide plates, Comp Promag roller rockers, Heads have been CNC ported and hand polished and intake matched to them. It has a K&N cold air intake, Pacesetter long tube headers going into a full magnaflow 3"exhaust system with "off road" Y-pipe. Cats and rear O2 delete. Engine has been custom tuned to match modifications and a laptop with tuning software will be included. Engine and trans are poly mounted. Drivetrain starts with a custom built 4l60e transmission utilizing all high end parts, Beast sunshell, z-pak 2-3 clutches, wide kevlar band, billet shift servos. It's equipped with a 9 inch 3000 RPM stall custom built torque converter with full lockup clutches. Driveshaft is a Denny's "nitrous ready" chrome moly 3 " one piece drive shaft with hardened yokes. Rear end is equipped with 3.83 gearing and a SLP rear support cover. Chassis has full 3 point weld in subframe connectors, BMR tubular torque arm w/ poly mount, UMI tubular lower control arms w/ poly mounts KYB AGX adjustable shocks. Car is sitting on a set of 2002 Corvette rims, 17 in the front with brand new bfg tires, 18 in the rear, those tires are in need of replacement Custom Audio system includes an Alpine W205 touch screen DVD head unit running 4 Alpine type R 6.5" coaxial speakers and a Precision Power Art series 300 watt amp driving a JL Audio 10 inch sub mounted in a custom hidden enclosure in the left rear wheel well. Serious inquiries only. Email learjet3@gmail.com
Can be seen here: 1997 Camaro Z28 highly modified
Old Mar 30, 2013 | 07:10 PM
Mike 92LX's Avatar
Re: 1997 Z28 Heads/Cam car
Good price and car. I can check it out in person if anyone needs to
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
ScottZ
Mar 3, 2004 01:34 PM
30thZ286speed
Aug 3, 2002 04:54 AM
