95 T/A 800WHP YSi Forged Stroker,9" rear lots of goodies!
Old Feb 12, 2013 | 01:58 AM
colts95ta's Avatar
Car:
1995 Firebird/Trans Am
Came factory with a 350ci LT1 & Six speed
118K miles on the body
1998 and up tail lights Smoked
Warbird fiberglass hood
Factory paint that is in gret shape considering miles and age.
C6 18" wheels with nitto 505s(275s) up front and Nitto drag radials out back(305s)
Alpine deck
kicker front and rear speakers
Kicker amps and Square 10" subwoofers
Motor: 383 LT1 Engine 4.030 Block, Zero Decked,
Converted to 4 bolt mains with Billet main caps
Ohio Crank 4340 3.75 Stroke Crank 2 piece rear main (double Keyed)
Ohio 4340 H beam rods
Probe Reverse dome blower pistons dish 9.0 to 1 compression
ARP Main and Head Studs
Melling HP high volume oil pump, upgraded drive
ATI BBC hub and ATI dampener
Cometic Head Gaskets
Bullet custom Blower grind Hydraulic roller Camshaft
LT4 lifters
Comp Chromemoly pushrods
Comp Guide plates
Comp Pro Magnum 1.6 roller rockers 7/16 stud
Stock casting Heads, Ferrea Valves, Inconel Exhaust Valve
Stock casting Intake hand ported/port matched
Teflon coated bearings
New GM water pump
MSD Billet Optispark
Msd Ignition and coil
MSD plug wires
NGK TR6 plugs
Canton Fabbed valve covers
Canton Oil pan with trap doors and kickouts
Be-Cool radiator with span 10" fans
Drivetrain:
Tremec T56
Steel flywheel
B&M ripper shifter
Spec stage 3+ clutch
Ford 9" rear(all podwercoated black)
Moser housing
Moser 35 spline axles
1/2"-20 x 3" studs
Strange 3.250" bearing Race Case
4.33 gears
35 Spline Detroit Locker
Aluminum pinion support
1350 Forged Yoke
Custom relocation brakets
Solid Crush sleeve
It also has welded on relocation brackets and sway bar mounts for the factory rear bar. Comes with lt1 backing plates.
C6 Disc brake conversion with slotted rotors and stock rear brakes
Removed ABS to make room for YSi Blower
Impire Aluminum driveshaft
Induction:
Vortech YSi Supercharger
Cogdrive 50mm 80T Crank w/ ATI dampener, 26T Supercharger( have a few different pulley set-ups)
Custom YSi Supercharger Brackets
Vortech Air to water intercooler(maybe a lil small for this HP range with figured I could Use meth also)
Stainless braided lines and AN fittings for the cooling water.
Vortech bypass
3 gallon fuel cell&pump mounted in the spare tire well for cooling water to intercooler
3" piping w/ T-Bolt clamps
Exhaust:
Headman stepped Headers(1 3/4"-1 7/8") ceramic coated
Complete custom dual 3" all the way out the back
Stainless Magnaflow Mufflers
Suspension:
Tubular K-member
Spohn torque Arm w/ Driveshaft loop and crossmember
Spohn Tubular Lower control arms
3 point Subframe connectors welded in before the underside was undercoated
UMI Adjustable Panhard bar
UMI panhard bar relocation Kit
Poly engine and tranny mounts
Poly Sway bar endlinks and mounts
KYB adjustable fronts and KYB rear shocks
Eibach Sportline 1" lowering springs
Full under carriage 3M undercoated
Fuel System:
Holley Billet 58mm Throttle body
75# ractronix fuel injectors with the versafueler. Very clean install.
Aeromotive A1000 Fuel pump,Aeromotive boost referenced regulator,5/8" feed line,1/2" aeroquip lines(poly stainless braid) and fittings.
Aermotive pre-pump&postpump fuel filters
Sumped factory fuel tank with return at the top.
Stock ECM currently.Was looking into the converting it to the EFI Connnection sysyetm with LS based ECM
Lingenfelter 100mm MAF
Interior:
Interior is completely stock/complete other than the gauge Pod and stereo.
Power window/locks
Leather seats in great shape
Removed spare tire and mounted a 3 gallon fuel cell in the for cooling water for the air to water inter-cooler. If i finished this car it would be for methanol.
All Glass in in great shape. everything works.
Now the bad part:
I have not messed with this car in some time.
I have lost interest and moved on to a C6 Z06
It does and will run but it definately needs tuned or some other EFI system put on it.
I have to many hobbies and projects going to finish it. the last time I drove it was on my wedding day.Sept 2009. We left the reception in it and
I purchased a GTO then a Couple Sportbikes and now on to a Z06 that is undergoing a full build. Car has been on the back burner for a while
I would like to sell it complete rather than part it out but If no one is intersted in buying it complete for tons less than it would take to
Build it I will part it out.
Sure wouldnt take much to make this a conservative 800 RWHP car.
I will start the price at $17000 OBO
I have tons of pictures of the car and lift in my personal shop so I can take pics of anything you would like to see.
Serious inquiries only!
I will find all my pics and get them uploaded to photobucket and post them tomorrow.
Thanks Fellas
found a couple motor shots on my phone. Im on nightshift...
Old Feb 15, 2013 | 05:32 AM
colts95ta's Avatar
16k obo.
Old Feb 15, 2013 | 11:16 PM
colts95ta's Avatar
Started parting it out on ls1tech.
SomeGuy25thZ
Dec 6, 2023 07:58 PM
carlin
Oct 24, 2012 07:58 AM
speed9
Mar 4, 2005 03:08 AM
Chas97SSConvert
West South Central
12
Jul 28, 2002 01:20 PM
