ac compressor
Old Jun 10, 2012 | 03:09 PM
94Z28LS1toLT1's Avatar
ac compressor
Hey guys i went underneath to look at my ac comp and there is freon in the center leaking from it. the line is new n the screw is tight behind the ac comp.but do i need to replace the ac comp.when i turn on the ac sumtimes the ac clutch makes a loud long noise n freon was leaking.
Old Jun 10, 2012 | 07:10 PM
parkers Z28's Avatar
Re: ac compressor
my 94 was leaking from the shaft had to replace the a/c compressor bad news is if its
making noise you might have to replace everything $1000 bucks from GM $700 from
tire shop cost me $120 to have GM to tell me what is wrong with it my advice is to take
it to the dealer ship and have them check it so you don't waste time and money
Old Jun 11, 2012 | 06:16 AM
Re: ac compressor
Thank u for ur response,replace everything as in wat bc the condesor is new lines are
new. Or do i just replace the ac compressor
Old Jun 11, 2012 | 08:14 PM
Re: ac compressor
take it to the dealer ship have them check it out it could have something going
on with the clutch if the a/c compressor locks up it will so they say send
trash metal fragments threw the system stopping it up if this happens
and you just replace the compressor the new one will get clogged up
from the old trash in system and they want warranty it unless you replace
everything since mine was just leaking i took a chance and just replaced the compressor
before you buy anything have it checked out first
Old Jun 11, 2012 | 09:54 PM
Re: ac compressor
Wat can i do to clean all the debris out i dont trust any dealers or shops id rather do it
myself but that compressor is old ive had this car for a 4 yrs n the owners b4 never ran the ac
Old Jun 12, 2012 | 04:16 PM
Re: ac compressor
the a/c is something that needs to done by a professional that has the proper tools
like a pressure gage that checks the high and low side, A/C vac that cost 8000 bucks
however people do it there self you will need a hand held vac/pump that sucks the trash
and moisture out of the system i think they cost like 30 bucks at auto zone?
auto zone also rents tools at some stores don't forget to put in a/c oil
and buy a new compressor not a refurbished one
Old Jun 12, 2012 | 07:16 PM
Re: ac compressor
Cool thank u,so like u said just make sure to put oil in the new compressor,i kno the compressor is old i can buy one n i can swap it to,i kno u said to let the pros but mechanics have screwed me n cant trust them i know i can do it thank u again
Old Jun 12, 2012 | 07:49 PM
Nickw059's Avatar
Re: ac compressor
You don't need "Everything" You just need a compressor and a receiver drier and gaskets. If your short on change you can get by with just a compressor and long as it didn't come apart and is just leaking. You can do everything yourself than take it to a small mom and pop shop and have them vac it down than charge it. It'll save ya a couple bucks that way. alot of shops usually wont charge you that much labor for vaccuming down and charging. it'll take 30 min plus the price of freon.
Old Jun 13, 2012 | 05:08 PM
Re: ac compressor
yep the tire shop was trying to get me to i would try not to use the a/c
until you get fixed that way it doesn't come apart so you don't have to
replace anything else
nick has a good point about putting the compressor on and then taking
it to someone and have them vacuum it out and recharge it
has to be better than the hand pump
i took mine to the shop with my new compressor installation and recharge $115
Old Jun 16, 2012 | 09:25 PM
Smile Re: ac compressor
Cool thank u parker n nick i will do that
2QUIK6
Sep 17, 2016 02:31 PM
Devinfoote87
Feb 12, 2016 03:21 PM
War Engine
Sep 18, 2015 07:28 PM
WPHIG2
Aug 27, 2015 06:37 AM
AtlasXVIII
Aug 24, 2015 11:41 PM
