Dashboard issues
Old Apr 10, 2012 | 08:20 PM
rrgnc's Avatar
Unhappy Dashboard issues
Dont know if this is where I need to post but I need HELP! I got into my 2000 z and lights,gauges,odometer,rpm,mph,radio,air...Not working at all!
Is it a fuse?
Help ASAP please
Old Apr 10, 2012 | 10:37 PM
mrmint69's Avatar
Re: Dashboard issues
Possible. Have you checked to see if it is? Do you know where the fuse is?
Old Apr 11, 2012 | 06:24 PM
rrgnc's Avatar
Just got through checking the fuses all good.
Old Apr 12, 2012 | 12:52 AM
mrmint69's Avatar
My son blew the fuse on his 98Z working on the radio and all the stuff you mentioned went out on his. I had him check the fuse and he said it looked good. After using a test light it was bad, but could not be seem until inspected closely. I would put a new fuse in there or swap with the same type and see if that is it. Using a test light takes 1 minute to check all the fuses in that group.
Old Apr 12, 2012 | 11:45 AM
rrgnc's Avatar
I used a tester, but I guess I can jus change'em out to see. Thanks
Old Apr 12, 2012 | 09:19 PM
rrgnc's Avatar
Changed out all fuses and it worked thanks for your help!
rocknroler69
Apr 29, 2015 10:24 PM
sseeya
Apr 9, 2015 06:38 AM
mackirockz
Feb 4, 2015 07:03 AM
Alex Barnes
Jan 24, 2015 10:21 PM
gh0st
Sep 1, 2002 10:24 AM
